02-04-2016, 05:39 PM | #1 |
Wheel placement help needed
Setting my cab. Not sure about wheel center. Does this look bout right
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
02-04-2016, 08:21 PM | #2 |
Re: Wheel placement help needed
Looks pretty close. Wheel may be turned a little left in that pic.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-04-2016, 09:48 PM | #3 |
what do you go by to level the cab from front to back? this is a 84 k10 chassis
02-05-2016, 07:24 AM | #4 |
I would level the frame on stands then level the cab. Leveling both front to back and side to side. Then once you have them both level you can center it. Them place the mounts.
Jimmy
02-05-2016, 07:58 AM | #5 |
Where on the cab do you actually place the level?
02-05-2016, 01:17 PM | #6 |
I would use the bottom of the rockers fro front to back and the rear cab brace for side to side. The longer the level the better.
Jimmy
