Old 02-06-2016, 03:43 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Need some ac/heater help
Taking the hose off the water valve and put your finger over it to see if it pulls on it are not. The 3 port was for 71 model trucks and up. The port on the bottom of the picture is the water valve. The center one from motor vacuum and top goes to each of the flappers outside closes with vacuum inside opens with vacuum.
Checkout the new picture it's highlited!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
