Old 01-22-2016, 12:15 AM   #176
namloc
namloc's Avatar
Re: The Snortin' bull
Just layin' some more pipe. I know these picture's are kinda boring though I have found that in the forum's we pick up subtle little helpful thing's in the picture's. Just need to trim and fit and finish off the tailpipe's. Install header flange to pipe gasket's maybe tip's and exhaust is done.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 01-22-2016, 12:43 AM   #177
Ronzo
Ronzo's Avatar
Looking good, nice progress.
Ronzo is offline   Reply With Quote
Old 01-22-2016, 11:36 AM   #178
namloc
namloc's Avatar
Thank you Ronzo.
The Snortin' Bull
Old 01-24-2016, 09:52 PM   #179
namloc
namloc's Avatar
rear pipe's together from mufflers back to rear behind bumper area.
The Snortin' Bull
Old 01-28-2016, 12:07 AM   #180
namloc
namloc's Avatar
Exhuast is all in and hung.Used Remflex gaskets at headers , pipe is 2.25" aluminized steel.Mufflers are Jones Exhuast.Moved suspension thru far and lowest position no interference.Front down pipes get close to the ground when aired down though.Might to redo those in future.
The Snortin' Bull
Old 01-30-2016, 08:38 PM   #181
namloc
namloc's Avatar
Went to fire the truck up today.Chased some leak's around though one at the carb would not stop. Got a little to gorilla like with this fitting.My day was done. For now.
The Snortin' Bull
Old 01-31-2016, 11:22 PM   #182
namloc
namloc's Avatar
Originally Posted by rwade View Post
Maybe I missed it, but are you using your factory idler arm? What center steering section are you using? What year power steering box too?
Thanks, Wade
I ended up using 1987 c-10 power steering gearbox.Same for the idler arm.The donor front crossmember was 1987. The center link is stock using CPP tire rod adapter sleeve's for a little bling.These adapt ausing both early and later tie rods end's .Sorry for the late response though all was coming together.
The Snortin' Bull
Old 02-01-2016, 03:57 AM   #183
Grizz1963
Grizz1963's Avatar
Like your pipe work.
Looking great.
I am looking forward to when I can eventually build my pipes.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-01-2016, 02:20 PM   #184
namloc
namloc's Avatar
Looking great.
Thank you, The pipe's and the small thing's are time consuming .
The Snortin' Bull
Old 02-03-2016, 12:39 AM   #185
namloc
namloc's Avatar
Repaired the fuel feed into BG Demon carb. Ready again.
The Snortin' Bull
Old 02-03-2016, 11:43 AM   #186
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Nice. Time to get it on the road.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-03-2016, 12:56 PM   #187
namloc
namloc's Avatar
Yes it is , Shake out the bug's, get it aligned. And continue with misc. I am getting excited.Time is what i have to find though.Work and life keep me busy.
The Snortin' Bull
Old 02-07-2016, 12:01 AM   #188
namloc
namloc's Avatar
Fully aired down. The truck was planned out to be able to cruise at full aired out. I did not build it to lay frame but to almost appear to and still slow cruise in show atmosphere. The pinch welds are just over an inch off the ground under the cab rocker's.
The Snortin' Bull
Old 02-07-2016, 12:03 AM   #189
namloc
namloc's Avatar
a bit of an engine starting tool kit ready to go.
The Snortin' Bull
Old 02-21-2016, 01:48 AM   #190
namloc
namloc's Avatar
So like a lot of the forum member's have said life get's in the way 2 week's go by with gas in the tank and key's in the cylinder. Today I started the GMC up .Broke in the cam and etc.Drove down the drive way a couple time's .Got a couple of video's though need a "golden" token from admin to post?
still got work to do.
The Snortin' Bull
Old 02-21-2016, 09:19 AM   #191
truck is looking good.
Palf70Step is online now   Reply With Quote
Old 02-21-2016, 11:02 AM   #192
CHIZZLER
CHIZZLER's Avatar
Truck looks great.
61-crew cab D-max
Old 02-21-2016, 10:32 PM   #193
namloc
namloc's Avatar
Truck looks great.
Thank's,Gettin there.It was a rush to go down the driveway and back.
The Snortin' Bull
Old 02-21-2016, 10:35 PM   #194
namloc
namloc's Avatar
GMC, The Bull is out in the weather now.Put in the final door surround weatherstrip on the cab.Sill plate's also.
The Snortin' Bull
Old 02-21-2016, 10:38 PM   #195
namloc
namloc's Avatar
I am on the fence to put on a rear bumper or not. Even though the exhaust tip's are hardly showing I still tipped off with a chrome pencil tip. Yosemite Sam street sweeper's I call them.
The Snortin' Bull
Old 02-21-2016, 11:20 PM   #196
Ronzo
Ronzo's Avatar
Wow, looking really good.
My vote is for a bumper, always.
Old 02-21-2016, 11:44 PM   #197
SFTorange
SFTorange's Avatar
Looks great. I enjoyed reading your build. I like your style, dig those hubcaps!
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 02-22-2016, 07:05 PM   #198
namloc
namloc's Avatar
A link to Video of truck on the driveway . https://vimeo.com/156134915
The Snortin' Bull
Old 02-22-2016, 07:08 PM   #199
namloc
namloc's Avatar
Thank you appreciate it.
The Snortin' Bull
Old 02-22-2016, 07:09 PM   #200
namloc
namloc's Avatar
I like the rig's you have posted on the forum also.
The Snortin' Bull
