![]() Join Date: Aug 2003
Motorhome Tilt Column
Nice clean,tight column. I hit shift arm area w/my sawzall, but welded slice up, that's why it's shiny on bottom. Needs paint. Has later style harness so you'll need pig tail to adapt to stock truck harness.Qwik has 1st shot at column. $225 shipped to lower 48. Please respond in post. 1st take it gets it.
Re: Motorhome Tilt Column
Aaaaa
Bbbbb
Ccccc
Dddddd
Eeeeee
Besides a pigtail what else would be needed to make this work in a truck? Next after qwik
One foot in front of the other
![]() Join Date: Aug 2008
I'll take it if gets to me.
I am interested in the cruise lever if whoever buys it is not using it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Qwik passed. Feller Neutral switch location and add metal retainer and rubber seals. Dpowers I'll give feller 24hrs to respond. I've been told column can be pushed closer to dash and neutral switch will clear but have never tried it.
I'll pass, more work than I am anticipating
![]() Join Date: Oct 2006
I got it from a pretty reputable source but like I said I've never done it. DPowers you up
pm sent
#15 |
Received today- Thanks
