Old 02-09-2016, 04:04 PM   #1
joejiz
Brakes found on 1969 CST/10 Pickup
Hi
Curious I am looking to buy a truck 1969 CST/10 Pickup, I see a master booster and master cylinder, does this mean the front brakes could be disk brakes from the factory? Were they offered EVER or is this a power assist manual drum brake setup?
joejiz is offline   Reply With Quote
Old 02-09-2016, 04:17 PM   #2
88Stanger
88Stanger's Avatar
Re: Brakes found on 1969 CST/10 Pickup
I have a 1969 C-10 CST and it had power brakes, but with drum all the way around. I am not sure if disc was offered in "69 or not.
88Stanger is offline   Reply With Quote
Old 02-09-2016, 05:09 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Although there has been some speculation that some of the last 1970 model C10's etc. had disc brakes none has ever been verified on this site. Disc brakes were standard equipment starting in the 1971 model year. As a footnote even though disc brakes were standard you could still order a truck without power brakes so you'd have manual disc brakes. Your truck with power drum brakes is factory and not uncommon.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Already Gone is online now   Reply With Quote
Old 02-09-2016, 05:19 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
A booster and master cylinder doesn't mean disc brakes. There are power assisted drum brakes. Check behind the wheel for a drum. If there are discs there... they were swapped in as no 1969 truck came from the factory with disc brakes.
I'm in the process of swapping 1972 disc brakes over to a 1969 frame.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-09-2016, 05:29 PM   #5
CC69Rat
CC69Rat's Avatar
Power drums from the factory on the 69 CST trucks (generally speaking, could be different in Canada ?) and as others have said if the truck happens to have disc on it they have been added at some point.
But, no it's not save to assume disc because of the booster / MC.
Welcome to the board !
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-09-2016, 07:17 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brakes found on 1969 CST/10 Pickup
No shop manuals for 70 and back mention disc brakes for repair so the answer is No!
The only way it would have disc brakes up front is if someone has changed them out. Look at the wheel studs. The 69 should be 6 lugs! If it was a swap they would be 5 lugs inless they used a aftermarket kit.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-10-2016, 03:48 AM   #7
joejiz
Thanks everyone, the truck is in usa and appears to have 6 lug nuts on rear so assume from has 6 as well. Can't see a disk brake upgrade being done.
Will have to have a look but will start another thread on that!
Thanks!
Old 02-10-2016, 09:30 AM   #8
70cst
70cst's Avatar
Agreed with most of the above - Disc brakes were ever an option in 1969 model trucks. At least I have never seen any documentation to prove such - Documentation is the key
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
