crankshaft journal scratches
I have a 350 4bolt that has a knock in lower end. I removed oil pact to inspect rod journals. Upon removing rod caps, on one of the journals I notice a definite scratch/cut going around the journal. When I do the "fingernail test" my nail can barely feel the "scratch"
My question is, what is the maximum tolerance for such a scratch if a tolerance is even acceptable here. There may be no room for any type of scratch on the journal. Just trying to figure out if I do need to have it ground. It is a scat crank. standard stroke, has not been ground before. Also, when inspecting the rod bearing, I do not observe any "visible" signs of wear. I do intend to get some plasti-guage to check the clearance to determine how much wear there is. Mike |
![]() Join Date: Jul 2000
Re: crankshaft journal scratches
A scratch that you can barely feel with your fingernail is no big deal. And all of the rod bearings look OK?
Maybe the knock is not from the bottom end. Are the flexplate or flywheel bolts tight? If auto trans, is the torque converter tightly bolted to the flexplate? How about the damper? Does it look OK and is it bolted on tightly? No valve train noise? Last resort might be to look at the pistons.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
you know when i was unbolting the torque conveter from the flex plate it only had 2 bolts in it. The other 2 were tight but it was missing a third
wonder if that could have been an issue. no noise from valve train at all flexplate bolts were extremely tight, had to use plenty of torque to get them off yes rod bearings showed no significant or abnormal wear or scratches. I will take pics of them and upload them for you to look at if you dont mind mike |
It would not surprise me one bit if you just found your knock.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#5 | |
Knocking could also be a broken piston slapping around. Ouch! I remember back in the day when guys would run forged pistons with .006" clearance or more. Those things would rattle and knock terribly until the engine warmed up.
