02-10-2016, 10:54 PM | #1 |
Steering Column
I have a 87 1ton in need of a steering column. What year and model will be a direct bolt in and not require any wiring modifications. It does not have cruise control.
02-10-2016, 11:36 PM | #2 |
Re: Steering Column
1984 and newer squarebodies
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
02-11-2016, 08:35 PM | #3 |
Re: Steering Column
Thanks. Now I know what to look for.
02-11-2016, 10:35 PM | #4 |
Moderator
Re: Steering Column
Better off to use 1985 and newer.
1984 had something odd about the column wiring where it wasn't completely compatible with the earlier or newer trucks. I've forgotten what it was at this point.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-12-2016, 02:17 PM | #5 |
Re: Steering Column
Hatzie, If you figure it out let me know. I sell a lot of rebuilt columns and would like to make sure my customers are getting the right thing. Do you know what year the key buzzers started? I end up with some turn signal switches that have it and some that don't but never paid attention to what year they came from
02-13-2016, 12:45 AM | #6 |
Re: Steering Column
Thanks for the update Hatzie.
02-13-2016, 01:00 PM | #7 |
Re: Steering Column
I bought a rebuilt column from this guy for my 82 C10. http://www.gmtiltsteeringcolumn.com/
I see where he also has 84-87 columns. Super guy to work with. Every time I called him, he either picked up the phone right away or called me back a few minutes later.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-13-2016, 01:34 PM | #8 | |
Moderator
Re: Steering Column
The harmonica connector part # is the same from 1978 forward so the slots are there for the wires. The cab harness would have to be populated to make it work. When I search the early parts books the only buzzers that show up are the 1976 and later RPO T63 Headlight Warning Buzzer and the seatbelt buzzer. Since the 1984 headlight warning buzzer uses the seatbelt buzzer it's not shocking that T63 starts the same year GM started buzzing the seatbelt. I can't find a special RPO for the key buzzer. The key inserted switch grounds Circuit 80 on the seat belt buzzer in the 1984 wiring diagrams. The 1978 GM wiring diagrams "Circuit Tabulation" lists circuit 80 "Ground Key Warning Buzzer" but I can't find that wire anywhere in the diagrams till 1984. My gut tells me it was available from 1978 forward but it may be rare till 1984. -------- The difference on the 1984 columns was the optional 1984 pulse wiper controller and wiper switch. If you update to the 1985 parts it will plug in and work fine. After 1984 there's no reason to use a 2 speed wiper switch. The delay/pulse wiper setup is a direct plug in with no wiring mods needed. The delay switch plugs into the delay module which plugs into the same cab harness connector as the 2 speed switch... The delay switch is cheaper too.
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-13-2016 at 01:46 PM. |
