Old 03-01-2004, 04:59 PM   #1
Gibble
mmmm....Rye and Coke
Gibble's Avatar
Maybe a stupid question...
Is it possible to convert a C10 to a four by four?
Gibble is offline   Reply With Quote
Old 03-01-2004, 05:14 PM   #2
Russell
Professional Grade
Russell's Avatar
If I were to do this, I would buy a rolling 4x4 frame and bolt my truck's body / engine to the frame's tranny / transfercase. It would by far be the easiest way to go about it, even though I'm sure there is some sort of conversion kit somewhere...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-01-2004, 05:18 PM   #3
Gibble
Gibble's Avatar
I figured getting a rolling 4x4 frame would be easiest.
I ask because I'm going to be swapping my engine tranny for a Olds 425/TH400 ... and I'd much rather have a 4x4 than a peg leg
Old 03-01-2004, 05:21 PM   #4
Prerunner1982
Prerunner1982's Avatar
you can, ask 1fastc10 i think he is doing it. it can be done, but like russell said, rolling chasis would be best. i have thought about it, but dont have the time, money or space to do it at the moment.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-01-2004, 05:22 PM   #5
Gibble
Gibble's Avatar
Would I need to use the tranny from the rolling chassis or would the TH400 work? I'm pretty ignorant of how 4x4's are setup.
Old 03-01-2004, 07:34 PM   #6
CRRoy71
The TH400 would work as long as it came out of a 4X4. If it came out of a 2X4, the tail shaft would need to be changed, as they are different between a 2 wheel drive and a 4X4.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 03-02-2004, 12:48 PM   #7
Gibble
Gibble's Avatar
The more I think about it, the more I think I should maybe just change my rear diff and keep it a 2wd.
And build a seperate 4x4
Nonetheless, Thanks for the help!
Old 03-02-2004, 01:26 PM   #8
Prerunner1982
just do like me, build a capable 2by....
Jon
Oklahoma Roll Call
Old 03-02-2004, 01:48 PM   #9
Gibble
Gibble's Avatar
What did you do?
Old 03-02-2004, 02:14 PM   #10
Prerunner1982
pretty much a well equiped truck (ex. tools, spare parts, chains, fire extinguisher, shovels..etc..) with large tires (32" at the moment, maybe 35"s with cut fenders) re-geared axle with locker at some point.... i also have full size spare, with cb, want a Ham radio as well....
Jon
Oklahoma Roll Call
Old 03-02-2004, 02:16 PM   #11
Gibble
Gibble's Avatar
I guess it's different when you want traction on ice...my parents 2wd couldn't pull my cavy out of a ditch (only ONE wheel was actually in the ditch!), the wheels just spun, got a 4wd and it yanked it out like a hot knife through butter.
Old 03-02-2004, 03:21 PM   #12
Prerunner1982
maybe it was the driver.. jk. mine doesnt have a problem at all, never has.. and here in Oklahoma it usually ices more than it snows..
Old 03-02-2004, 03:51 PM   #13
Gibble
Gibble's Avatar
It may have been the tires and the fact it had NO weight in the back...
