#26 |
Future TOTM Winner
Re: Looking For Blazer Frame Dimesions
Right click...SAVE IMAGE!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#27 |
Boosted Member
What are the differences between 2wd and 4wd frames?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#28 |
But we can't do this all day as the pitchman say. Here you go: 1971 4x4 Blazer frame dimensions. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 01-07-2010 at 09:11 AM. |
#29 |
Great, thanks again.
#30 |
"something witty here"
definitely
![]() Do they have these for shortbox 4x4, I think my frame is bent or twisted and need to find original measurements.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 01-07-2010 at 01:31 PM. |
#31 |
Thanks Rod for posting both frame dimensions, this helped me get proper trailing arm placement on a 4x4 blazer frame, I have looked thru many posts and not found these critical measurements...Thanks again....Ed
#32 |
Insane In The Membrane
This is what I've found for 4x4
#33 |
Oops, already been posted.... helps if I look at the second page huh.......
#34 |
That's Good that it helped you out notsolo. Glad to see it made it a useful thread for yah.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#35 |
Anybody know the weight of a 2wd blazer frame?
Posted via Mobile Device |
#36 |
Without front x member.
#37 |
![]() Join Date: Jun 2013
has anyone ever found the 4x4 shortbed dimensions? I'm trying to figure out how different the rear mounts are from a k5 frame
#38 |
You clearly know what you are doing, you’ve covered so many bases.Thanks!
#39 |
I know this is an old thread, but I have to ask...
Rod do you remember where you found these images? I'm wanting to see the measurements that were cut off on the top, like what I attached which is for a 2wd short wheelbase frame. ![]()
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#40 |
Factory Assembly manual.
Check your pm.
#41 |
Thanks!
#42 |
