Old 02-14-2016, 04:27 PM   #1
happy1970GMC
Angry engine dies in 15 minutes
1970 GMC probably a '72 engine, 350, Q jet, auto tranny. Just replaced the mechanical fuel pump. It still dies at 13 to 15 minutes, and it will have to cool down for at least an hour, then do it again. Any help would be appreciated.
happy1970GMC is offline   Reply With Quote
Old 02-14-2016, 04:38 PM   #2
68350
68350's Avatar
Re: engine dies in 15 minutes
What does it have to cool down for an hour? Will it not restart or?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 02-14-2016, 04:59 PM   #3
happy1970GMC
It will turn over, but not fire. I've checked the gas cap, no vacuum in the tank. Just replaced the fuel pump, I can pull on the throttle and squirt fuel in the carb.
Old 02-14-2016, 05:32 PM   #4
68350
68350's Avatar
Do you have an HEI distributor? Almost sounds like the control module or something is bad and when it gets heated up, it's causing the truck to die. Another thought I had was the motor is running too rich and maybe flooding itself out? Are your spark plugs wet?
Old 02-14-2016, 05:57 PM   #5
Ed F
Ed F's Avatar
Sounds like it could be a plugged fuel filter to me
Ed F is offline   Reply With Quote
Old 02-14-2016, 06:08 PM   #6
Ken O.
Just had the same thing on my 67 GMC. It had the points distributor on it. After it ran for a while, 10-15 min it would die, then not start again, Wait an hour and it would fire up and again after 10-15 min it would do the same thing again. I went through EVERYTHING and finally put a new HEI distributor in it and it runs perfect now, no issues in 2 months.
Ken O. is offline   Reply With Quote
Old 02-14-2016, 06:22 PM   #7
davepl
davepl's Avatar
The HEI modules can get flaky when hot - if you have a spare distributor, that'd be my guess. My first guess was tank venting, but you said no vacuum, so HEI it is!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-15-2016, 12:52 AM   #8
happy1970GMC
Thanks for the ideas, I'll get back to it next weekend.
Old 02-15-2016, 01:03 AM   #9
87Skier
87Skier's Avatar
Had a 1990 Suburban do the same thing. Just needed new cap/rotor, plugs, and wires. Ran perfect after that. Check that distributor too.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 02-15-2016, 02:18 AM   #10
swamp rat
swamp rat's Avatar
Something else, there is a short rubber hose below the tank, if its getting old and rotted it can collapse and restrict fuel flow, that includes any rubber line between the tank and pump, make sure its actual fuel line that is reinforced and not non reinforced rubber hose...
Check the filter like previously mentioned, try and back flow it with some air and see if there are any fine white chards of material in it, if there is that is the pickup sock deteriorating, time to replace the pickup screen.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-15-2016, 11:07 AM   #11
Davidf
+1 on ignition related components failing after heating up. Not too long ago, I purchased 64 Corvair and installed all new ignition parts. A mile or so down the road and it stop dead in its tracks. I decided to replace the points, condenser and ignition coil again...all was well the second time around. So, BOOB (Bad Out Of Box) parts are not uncommon.
Davidf is offline   Reply With Quote
Old 02-15-2016, 11:12 AM   #12
zeldman
zeldman's Avatar
If it is the old points and condenser distributor, sounds like the coil is breaking down. To test it, remove it, then shake it, If it makes a sloshing noise replace it.
Could be the same for HEI.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 02-15-2016, 01:36 PM   #13
happy1970GMC
Thanks for the ideas, I'll check them out.
Old 02-15-2016, 05:06 PM   #14
praisegeetarman
Check that the fuel tank is venting. If you remove the gas cap and the problem goes away, then that's what it is.
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find)
67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find)
Keith Riel
praisegeetarman is offline   Reply With Quote
Old 02-15-2016, 06:18 PM   #15
rripp
I would bet its the coil.
rripp is offline   Reply With Quote
Old 02-15-2016, 08:05 PM   #16
snipescastle2
snipescastle2's Avatar
Talking Re: engine dies in 15 minutes
Also, if you replaced the hei module recently and didn't use the dielectric grease,the module will fry to a crisp.... just sayin'
Ben
snipescastle2 is offline   Reply With Quote
Old 02-15-2016, 08:11 PM   #17
davepl
davepl's Avatar
He said no vacuum in the tank in his initial description.
Old 02-15-2016, 09:10 PM   #18
kilrcady
fuel filter
kilrcady is offline   Reply With Quote
Old 02-16-2016, 12:43 AM   #19
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Tank vent > fuel filter > distributor.................More likely distributor than fuel filter, but a filter is cheap and easy. If all that fails, I'd replace all fuel lines, including the vent line. If that fails, couldn't tell ya.
Don't know if that could be a fuel pump. Seems it would work or it doesn't.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-16-2016, 12:02 PM   #20
snipescastle2
Just something to check, but is there any fuel coming out the "Weep Hole" by chance? might want to make sure you have no fuel getting into your oil pan also....
Ben
Old 02-21-2016, 01:08 AM   #21
happy1970GMC
Hello to anyone reading this, I put a new coil in today and doubled my run time. Now it will run for about 30 minutes. I bought a remote starter, but haven't figured how to hook it up, the directions are for a more modern vehicle. Can a part store test my module for me?
Old 02-21-2016, 05:44 AM   #22
EARNHARDT#3
EARNHARDT#3's Avatar
I don't think so. They sure can sell you a Chinese one that won't last either though. I have a stash of GM ones incase I ever need them. Go to the JY and grab a few if you can. Around here you won't really find anything that old but maybe you have a yard with older stuff nearby.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 02-21-2016, 11:36 AM   #23
Grumpy old man
Grumpy old man's Avatar
I still say it's a fuel issue , The dist ,coil,capacitor ,and anything else wouldn't continue to start multiple times and just run for 13-15 minutes ,It would have completely failed already .
Dirty fuel pick up in tank
Fuel line between tank and hardline under cab collapsing / cracked
Inline fuel filter
Bronze fuel filter in carb
it starts ,runs until crud in fuel line restricts flow .Won't restart ,wait an hour fuel flows back clearing line and restarts .Dies if 13-15 minutes . Why no pictures ? a good look at the condition of the rest of the engine/fuel lines and ignition could let someone give a further diagnosis .have you tried starting it once it dies using carb cleaner to see if it will fire even for a few seconds ?
Old 02-21-2016, 11:46 AM   #24
Grumpy old man
I just red back thru your threads ,You've been dealing with this issue since 6/2012 ? Take it to your local mechanic .
http://67-72chevytrucks.com/vboard/s...d.php?t=528601
http://67-72chevytrucks.com/vboard/s...d.php?t=529028
http://67-72chevytrucks.com/vboard/s...d.php?t=534240
Old 02-21-2016, 12:06 PM   #25
Gromit
"I bought a remote starter, but haven't figured how to hook it up, the directions are for a more modern vehicle".
If you bought the Actron Remote Starter I believe it is in the instructions (Figure 5) - (see attached pdf)
Re using the remote starter I found it more convenient to just install a permanent 12 gauge wire from that "S" lug on the solenoid up to an insulated lug (really just a 1/4"-20 x 1" bolt through a chunk of plastic) mounted on the inside passenger side fender well next to the factory distribution block - then you can hook up the remote starter wires - one to that bolt and the other to your positive on the battery - without having to thread the leads through the headers and into the cramped space around the solenoid where it is easy to short against the positive cable.
Always turn your key to the run position before activating a remote starter (as advised in most repair manuals)..
Gromit is offline   Reply With Quote
