Old 02-15-2016, 12:37 AM   #1
craigg1
Parts swap with 2001-2002 Silverado/Tahoe
Ive been thinking about buying a running 2001 or 2002 Silverado or Tahoe with a 5.3 engine and a 4L60E transmission and using that to put into my 68 C10. I can find one in my area with about 150,000 miles for about $3,000-3,500 and just replace some parts. Not sure if I want to go this route or if it would be cheaper to just buy the engine and transmission cheaper by themselves.
My question is, if I buy the whole vehicle, could I use the A/C parts and the disk brakes (and whatever other parts) from the Silverado or Tahoe for my 68 SWB truck? My truck is not an A/C truck, but would want that at some point. Any thoughts or suggestions welcome.
craigg1 is offline   Reply With Quote
Old 02-15-2016, 01:00 AM   #2
87Skier
87Skier's Avatar
Re: Parts swap with 2001-2002 Silverado/Tahoe
As someone that has bought parts and bought entire trucks, it's usually a lot cheaper buying the whole truck, especially if it's wrecked. All the little parts add up fast.
Using the A/C stuff will work. You will need an evaporator in the cab, but you can use the condenser, drier and a bunch of other stuff. It is probably best to use the newer style condenser in your truck anyway.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 02-15-2016, 01:04 AM   #3
craigg1
Thanks 87Skier, I was hoping to hear someone say that was the best route to go because I would rather know that what im buying actually is a good running engine and transmission. Also, I know the parts add up fast. Would it be a problem using the disk brake setup as well? Thanks for your response.
Old 02-15-2016, 08:38 AM   #4
MARKDTN
There was a post a few months back where a guy put a '71 cab and bed on an '01 Tahoe frame. Never saw the finished photos but it looked good what he had.
No, you cannot use the '01 brakes on your 67-72.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-16-2016, 02:18 AM   #5
C10hacker
I have full access to a 2002 silverado and have the same question. I was planning on waiting on the Ls swap until later but with the AC being a possibility with the swap as well... I might be looking into that sooner rather than later.
The seats are coming out tomorrow to get mocked up in my 67.
I'm bummed the brakes won't work though
I'll be back to this thread
C10hacker is offline   Reply With Quote
Old 02-16-2016, 04:13 PM   #6
87Skier
87Skier's Avatar
That's what I figured. I have mostly 4wd stuff so I know that you can't swap stuff from solid axle to IFS, but wasn't sure on the 2wd trucks.
Old 02-16-2016, 04:57 PM   #7
michael bustamante
michael bustamante's Avatar
i have a yukon that is being a doner. 5.3, 4l60, 2wd, disc brake rear 3:73.
the yukon i have is coil spring and im thinking of using this but the rear end is narrower than a silverado truck rear end and ill be cutting off alot of mount brackets!
Ill ave to fab something to make the rear e brakes work as well
Also, i wont be able to run my fat 15" wheels. they will not clear the caliper.
1967custom
michael bustamante is offline   Reply With Quote
