Old 02-15-2016, 02:59 PM   #26
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Lets see your gauge panel!
I can play
Old 02-15-2016, 04:10 PM   #27
mjh1965
mjh1965's Avatar
Here's mine ready for the rebuild
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 02-15-2016, 05:03 PM   #28
The1960APE
The1960APE's Avatar
Here is the Apache
Sorry for bringing in a non truck panel , I figured I would post it for Idea sake, this is one we built for my 65 Olds 442
The1960APE is offline   Reply With Quote
Old 02-15-2016, 05:17 PM   #29
forestb
forestb's Avatar
Not a good photo but here you go.
forestb is offline   Reply With Quote
Old 02-15-2016, 06:59 PM   #30
WOLFMANmike
WOLFMANmike's Avatar
here is mine ... you cant tell in the pic but the paint is metal flake red
WOLFMANmike is offline   Reply With Quote
Old 02-15-2016, 10:15 PM   #31
65Gregg
65Gregg's Avatar
I'll play...
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-15-2016, 11:42 PM   #32
siggyfreud
siggyfreud's Avatar
Not ready yet . . . but a mockup of what it will look like when done. Getting some new tools (dust collector) to help in my machining process, as milling plastic makes it look like a thousand mice took a poop in the garage.
siggyfreud is offline   Reply With Quote
Old 02-16-2016, 08:26 AM   #33
Mackie
Mackie's Avatar
I cut "windows" in the Gen and Oil circles to match the shape of the other gauges then RTV glued ebay (70's Jeep I think) gauges to the back side.
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 02-16-2016, 10:35 AM   #34
vin63
It's Better With Nitro
vin63's Avatar
The instrument cluster for my '63 Poncho C10:
Faceplate milled from sheet aluminum:
Bezel painted, faceplate anodized, polycarbonate lens milled and lettering applied:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-16-2016, 03:41 PM   #35
Hop
Originally Posted by 65Gregg View Post
I'll play...
Man that's nice where did you find that look.
Hop is offline   Reply With Quote
Old 02-16-2016, 03:59 PM   #36
Jferrante
Jferrante's Avatar
Here is my mini "restoration" - got new gas gauge and new plastic cover. Sanded and resprayed the frame.
Before:
After:
Jferrante is offline   Reply With Quote
Old 02-16-2016, 11:23 PM   #37
65Gregg
65Gregg's Avatar
eBay, I powder coated the stock bezel and the billet panel satin black, thanks.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-16-2016, 11:44 PM   #38
61ChevyPanel
Active Member
61ChevyPanel's Avatar
I made the aluminum panels myself. The light switch was easily moved under the dash and mounted vertically so it's not visible. I removed the ignition switch since it's not going to stop anyone from stealing these type of trucks anyway. I used real aircraft switch covers painted black with toggle switches in the center. The switches fit it the ashtray & heater control holes.
61ChevyPanel is offline   Reply With Quote
Old 02-17-2016, 11:37 AM   #39
harrison56
tryin agin
Last edited by harrison56; 02-17-2016 at 11:51 AM. Reason: diot know what I'm doin
harrison56 is offline   Reply With Quote
Old 02-17-2016, 04:37 PM   #40
SnS C10
SnS C10's Avatar
Here's mine. Machined out of 6061 aluminum. Painted myself
SnS C10 is offline   Reply With Quote
Old 02-17-2016, 09:44 PM   #41
Tazimafied
Before:
After:
Quick tip:
Want the "red" back in your temp, gen and oil lights? Lens repair tape from your local parts store will work wonders.
Tazimafied is offline   Reply With Quote
Old 02-17-2016, 10:06 PM   #42
Haaland
Still a work in progress.
Haaland is offline   Reply With Quote
Old 02-17-2016, 10:43 PM   #43
markeb01
Senior Enthusiast
markeb01's Avatar
After a variety of panels that never really satisfied me, I finally had my son machine up an aluminum panel that fit over the steel back panel giving more of the old original GMC look to it. It's suffered many more changes since inception, but those dash panels have remained the same.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-18-2016, 03:51 AM   #44
Spry69
Spry69's Avatar
Originally Posted by Vernski View Post
Here's one for a GMC I painted the back ground satin black and it looks a little better but I'm still not satisfied, I found some engine turned alunimun sheet stock at www.speedwaymotors.com Part # 911-39520-24 6x24" .063 thick so it shouldn't be to hard ti cut out in the stock configuration as back ground. The stock bezel on these are plastic, does any one know of any where that you could get the plastic chrome plated again there must be somebody doing this somewhere don't you think? I do like the stock configuration with the exception of the idiot lights I may get some smaller jewel faceted lights instead and put in there place. Anybody have anymore ideas for ?---Vernski
Looks very nice. I have a 64 GMC, and would like to have it look like yours. I'm trying to figure how to get an oil pressure gauge in the mix. Looks great. Good work. Brandon
Brandon
Spry69 is offline   Reply With Quote
Old 02-18-2016, 03:53 AM   #45
Spry69
Spry69's Avatar
Originally Posted by WILDSTANGRACING View Post
heres a couple
Very nice!
Brandon
Old 02-20-2016, 02:27 PM   #46
1strong63
1strong63's Avatar
here's mine with the french speed limits cause i already get 2 tickets...
1strong63 is offline   Reply With Quote
Old 05-16-2016, 02:28 PM   #47
forestb
forestb's Avatar
just redid mine
Old 05-16-2016, 02:29 PM   #48
forestb
forestb's Avatar
sorry forgot photo
Old 05-16-2016, 09:45 PM   #49
ironman3452
ironman3452's Avatar
my question is, was your original gauge panel, messed up or did all here just want to make it look different, do not get me wrong, I just wondered.
ironman3452 is offline   Reply With Quote
Old 05-16-2016, 10:27 PM   #50
forestb
forestb's Avatar
My speedometer was not working and the oms on my fuel gauge were different than the ones on my new tank and I wanted to add oil, water temp, volts and a tach without cluttering up my dashboard. I had the original gauges and the tach on the column and the extra gauges on a separate panel under the dash and it was all too cluttered for my taste. Here is an old photo of the same setup when it was all black and installed. I made it white to mach my new paint scheme. That is supposed to be white. It looks a little yellow in the photo.
