axle swap question
I have a 69 chevy with a closed knuckle front axle and I would like to swap it to a 77 open knuckle that I have the donor blazer sitting in my yard, my question is the spring pads are 7/16 farther apart on the 77 then on the 69 and the overall axle length is 1 inch longer on the 77, has anyone else ran into this issue, any help would be appreciated.
Re: axle swap question
They are actually the same distance apart. It's pretty much a bolt in deal, steering arm and brakes, maybe shock mounts are differences.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
The spring mounting points on the axle (pads) determine the spread of the springs. They should spread the 7/16". The extra axle width is fine.
![]() Join Date: Apr 2001
lank, I've bolted in a '77 D44 under my '67 build without any problems. Also a D60 without any issues. Don't sweat it, IMO you'll be GTG. Again, this is my experience. YMMV (My CYA move!)
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
![]() Join Date: Feb 2004
I used an 88 blazer gm 10 bolt with no problem on my 67.
Is the transfer case the same also?
![]() Join Date: Mar 2003
![]() Join Date: May 2012
Are you asking if it matters if the transfer cases are not the same. It does not matter. Even if your pinion yoke is not the same you can resolve it with u joint. Your prop shaft should bolt in. But for a sanity check, you should check he front pinon angles and front shaft length. Measure and log angles with vehicle on the ground. Check again after swap. Everything will be close to before swap and you will sleep better knowing it. You should be fine.
White K20 |
