Old 02-18-2016, 12:53 PM   #276
60chevyjim
60chevyjim's Avatar
Re: A 15 year old's project. Rusty 62 stepside
the cab supports are $17 each from LMC .
you can go to there online catalog and see a picture of them on there .
here are some pictures of the bottom of the cab , on one of the 65 C-10 's
that im building now . this is my friend J.B.'s truck cab . it is the better one of the two .
60chevyjim is offline   Reply With Quote
Old 02-18-2016, 01:32 PM   #277
65sub
65sub's Avatar
Tailgate looks good Nik. You're right the only way to learn is to do it yourself. And if it's not right do it again. We have to redo stuff plenty out in the shop.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-18-2016, 05:48 PM   #278
62stepside longbox
62stepside longbox's Avatar
you can go to there online catalog and see a picture of them on there.
Thanks for the pics Jim
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-18-2016, 06:02 PM   #279
62stepside longbox
Re: A 16 year old's project. Rusty 62 stepside
Thanks for the compliments dale
Old 02-18-2016, 09:03 PM   #280
62stepside longbox
Having some troubles with my carb. Any advise?
Video: http://youtu.be/K9Ab9QcJN4w
Old 02-19-2016, 06:20 AM   #281
At a minimum, rebuild the carb. It is probably gummed up inside, valves sticking some, and those leakey gaskets..... I am not an expert with them, but those old 1bbl carbs are pretty easy to rebuild. Check around were the throttle rod(?) runs into the caarb and make sure the hole is not to wallowed out as then you may need another carb.
Old 02-19-2016, 04:20 PM   #282
mattfranklin
mattfranklin's Avatar
Glad to see you're taking the time to do it right, even if it means backtracking on previous progress. That's what the really good builders do. I think you'll feel a lot better about the end product.
Originally Posted by 62stepside longbox View Post
Hello everyone, I hate to admit it but I screwed up. The panel that I just put on the tailgate didn't quite workout the way I wanted, I tried to keep as much of the original metal as possible but ended up messing up the line because some of it was new and some of it was the old metal and the bends didn't line up correctly. I wanted it to be right so out came the angle grinder with cut off wheel. I then made a new panel and made it go down the same amount all the way across. Got it welded on but still need to grind the welds down. I'm very satisfied with it now it's pretty much perfect.
The old panel ripped off
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 02-19-2016, 04:44 PM   #283
62stepside longbox
Thanks, yes I'm very glad that I redid it and took the time to plan it out the second time.
Old 02-19-2016, 04:55 PM   #284
62stepside longbox
Just took the welds down. I'm glad that I took the time to make the panel even and flush. The seem is super smooth and I can't even feel the seam when I run my finger across it.
Old 02-19-2016, 04:57 PM   #285
62stepside longbox
02
Old 02-19-2016, 04:59 PM   #286
62stepside longbox
03
Old 02-19-2016, 08:36 PM   #287
60chevyjim
60chevyjim's Avatar
the tail gate looks much better this time !!
Old 02-19-2016, 09:58 PM   #288
rusty76
rusty76's Avatar
Looking good dude
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-19-2016, 11:13 PM   #289
62stepside longbox
Thanks Jim, yes I agree it looks much better
Originally Posted by rusty76 View Post
Looking good dude
Thanks rusty
Old 02-20-2016, 12:52 AM   #290
62stepside longbox
Just finished the fan base. Lots of filing and sanding resulted in the the areas replaced with fibreglass looking like they were meant to be. Then threw some paint on. I'll put it all back together tomorrow and put in the new switch.
Oh yeah I also ordered new rear cab supports and they should be here tomorrow or Sunday.
Old 02-20-2016, 04:08 AM   #291
62stepside longbox
Got the fan all assembled and the new switch wired up
Old 02-20-2016, 11:43 AM   #292
TJ's Chevy
TJ's Chevy's Avatar
Nice job bud!
Old 02-20-2016, 06:35 PM   #293
62stepside longbox
Originally Posted by TJ's Chevy View Post
Nice job bud!
Thanks tj
Old 02-20-2016, 06:40 PM   #294
62stepside longbox
Got busy this morning and patched the rust in the lower front cab pillar.
Old 02-20-2016, 06:43 PM   #295
62stepside longbox
Then I started to work on the rocker panel. I got this one for free from someone that messed it up. For some reason they cut out the front section of it
Old 02-20-2016, 06:46 PM   #296
62stepside longbox
After some welding and grinding I got it right
Old 02-20-2016, 06:48 PM   #297
62stepside longbox
Rocker all fitted and welded in
Old 02-20-2016, 06:50 PM   #298
62stepside longbox
02
Old 02-20-2016, 11:11 PM   #299
62stepside longbox
And here's a video of the dash fan to finish off the day
http://youtu.be/9_VBrqC5SzU
Old 02-21-2016, 02:24 AM   #300
TJ's Chevy
TJ's Chevy's Avatar
That dash fan is sweet! Nice patch repairing.
