02-21-2016, 12:44 PM | #1 |
63' Steering Column/Rod Modification
So, been looking at the different steering shaft swaps. The most common is the Jeep, but bottom line, it uses a 3/4-30 spline for steering gear side. The 63's, and I guess manual steering boxes, use 3/4-36 spline. Looking for a "Jeep" equivalent, cheap, alternative, but with a 3/4-36 spline for the OEM manual steering gear. The key here is cheap. Amazon you can get the whole Jeep piece for 100. Borgsen, CCP, and Flaming River are there but looking at 250 and upwards for a collapsible, u-jointed replacement of the rag jointed 3/4" smooth steering shaft. Dampened would be nice but not necessary. The joints themselves are in the 70, or 115, dollar range, depending on a joint or dampened joint, and then paying for collapsible rod (3/4 and 1 DD).
Ideas, thoughts, or just suck it up? Thanks in advance, Leadbelly |
02-21-2016, 03:22 PM | #2 |
Moderator
Re: 63' Steering Column/Rod Modification
CPP has them: p/n: CSS736730 3/4" -36 column u-joint, 3/4" -30 rag joint, each $119.00 - They are on this page: http://www.classicperform.com/Store2...l-products.htm
The Truck Shop has them for $119.00. Or you could use this and make one: http://www.ebay.com/itm/Rag-Joint-St...16.m2516.l5255
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-21-2016 at 03:29 PM. |
02-21-2016, 06:38 PM | #3 |
There you go, your the man! Gonna have to give them a shout in the morning.
I have a tough time navigating that site sometimes. Thanks a bunch, Leadbelly |
