Alternator Replacement Question
All about them K’s
![]() Join Date: Jun 2014
Re: Alternator Replacement Question
I used a later model 64(?) amp Delco 10si internally regulated alternator. Is bolt on and with a few very simple wiring mods it by passes the external regulator system that the O.E. unit uses. They can be found on square body trucks amongst many other applications. They are readily available at the local parts stores.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 02-21-2016 at 09:01 PM. |
I generally take an opportunity like this to convert to an internally regulated alternator, but if this one was meeting your needs before it failed, just get the direct replacement at your favorite parts store. Don't change anything.
If it -wasn't- putting out enough for your truck, read up on the conversions. Stay away from the seduction of "one wire alternators". You lose a number of features, like the idiot light, field excitation, and so on. You have to (usually) rev them up to get them to start charging the first time too.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I would just get the OE replacement from your nearest auto parts store. I'm running one and it is working just fine on my 72.
One last thing, is it possible the voltage regulator is bad and causing the alternator to put out a low voltage? Is there a way to check that separately?
![]() ![]() Join Date: Feb 2009
I'm replacing my perfectly good alternator for one internally regulated. Unfortunately I'm still using the one I have. Don't know about the wiring, but it doesn't matter anyway, because I'm replacing all that too.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Most auto parts stores can bench-test an alternator. If it's fine, then I'd suspect the regulator.
Growing up on the prairies where the next "big town" can be 6 hours away we used to carry spare belts, water pump, regulator, alternator, and fuel pump. Those are the "maintenance" items on a GM of that era.
| Bookmarks |
