Old 02-21-2016, 11:10 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
53 truck with 60-62 frame
I got a 53 Chevy pickup that someone put on a 60-62 Chevy pickup frame. They did not finish, it's a project. I will not be using the front suspension, it's too wide, and they torched off the T bars, but I am thinking about using the frame and rear suspension. Has anyone here used the rear coil spring suspension? How does it compare to leaf springs, or 3 or 4 link? The truck would be for street use only.
PDW HOTRODS is offline   Reply With Quote
Old 02-21-2016, 11:24 PM   #2
Advanced Design
Advanced Design's Avatar
Re: 53 truck with 60-62 frame
I haven't experienced one though No Limit Engineering makes a trailing arm rear suspension for the 47 to 54 truck. http://nolimit.net/products#!/Rear-T...tegory=6257097
Advanced Design is offline   Reply With Quote
Old 02-22-2016, 03:24 AM   #3
mr48chev
mr48chev's Avatar
I've tossed the idea of putting a trailing arm rear suspension under my 48 as I have a trailer made out of a 70 longbed that we used to have before I rolled it 25 years ago.
I'd take a serious look under yours before doing anything though and see how the cab bed and nose were mounted and what the workmanship looks like. You may be better off scrapping that whole chassis and putting and S-10 or stock 3100 frame under it.
My ongoing truck projects:
Old 02-22-2016, 11:30 AM   #4
jweb
jweb's Avatar
Here's a build where they are using a trailing arm suspension:
http://67-72chevytrucks.com/vboard/s...=569491&page=7
I'm also just starting to install a trailing arm suspension but I don't have a build thread. I think it will ride really well. But if it were me, I would start with a stock frame or S-10. Seems like it would be alot of work to make the 60's frame work.
jweb is offline   Reply With Quote
Old 02-22-2016, 12:38 PM   #5
PDW HOTRODS
The 60-62 Frame is uncut other than the torshon bars were torched off. The cab mounts are not welded to the frame, but are with the cab. The bed looks like it will mount to the frame fine. I have a 78 Malibu I will use the front suspension out of. I have used it before and it works and fits great. I have always used stock frame with leaf springs in back, but thought this might work ok.
Old 02-22-2016, 01:35 PM   #6
jweb
jweb's Avatar
I say go for it. The Malibu front should be a good width if you can adapt it to the 60 frame. The trailing arm rear and '60 axle width will be good for the back
