Hidden hitch with factory bumper
Has anyone used a hidden hitch with a factory bumper? Besides the hitch being ugly hanging down my truck is too low for it. I would assume it would work the same as a rollpan. I may have to get a custom built "stinger".
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
Re: Hidden hitch with factory bumper
The 'hidden hitch' hides the hitch assembly, not the hitch receiver. I have one now on mine with a factory bumper. It doesn't look bad.
If you want one that sits completely behind the bumper, they do make roll pans with the hole cut in it. I used to run one of those before going back to the stock bumper. It was a pain in the ass with the spring loaded license plate frame.
Mike |
#3 | |
Any pics? Maybe with the receiver in it? I would use a drop receiver flipped upside down
Here you go. I added the 7 pin connection which I bolted to the hitch, and the links since my one trailer's hooks won't hook to the ones on the hitch. I don't keep the spare tire underneath, but if you do, you'll need to move it a little when you put the hitch on.
Mike |
I'm hoping to make it where the receiver comes out behind the license plate. I don't want it to hang down lower than the bumper at all
with a little fab work, it should be doable. definitely need to look at the bumper brackets and hitch brackets. if nothing else, a good fab shop could make exactly what you need.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
Good thinking. I might just let a welding shop build one.
| Bookmarks |
