Old 02-22-2016, 07:00 PM   #1
Davidf
Re: Starting my engine build
Originally Posted by Mrturner1 View Post
What's the best way to make sure the timing is set right and to drop the distributor in? I read to rotate the engine to 5 degrees BTDC, then put distributor in with number one wire lined up with the pointer
If you lined up the dots on the cam and crank gear, don't forget to rotate crank 360 degrees before installing distributor pointing to plug wire #1. If you don't, you distributor timing will be 180 degrees out.
Davidf is offline   Reply With Quote
Old 02-22-2016, 07:24 PM   #2
Mrturner1
Thanks for the quick response!
Ok so it was at #1 TDC and I adjusted half the valves, then I turned it one full rotation so the #6 was at TDC, then adjusted the remaining valves. I haven't rotated it since, so just to clarify, I need to rotate one more full turn to be back at #1 TDC and THEN drop the distributor, correct?
Mrturner1 is offline   Reply With Quote
