Tail pipes on lowered trucks question.
I have lowered mine 5/7 ish and was wondering if any of you guys have had kickback from your muffler shops about running the tail pipes over the rear axle.
Re: Tail pipes on lowered trucks question.
A good shop should be able to do this no problem. There is less room for tubing in the back of an import hatchback. The truck, by comparison, is s-p-a-c-i-o-u-s.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Diggin The SquareLife
I have mine coming out before the rear wheels and mine is 5/6
I have nearly a 7/9 drop on mine and was still able to run 2 3/4 tail pipes up and over the axle with no problems.
Dont mean to hi jack but it is related,
I`m planning to lower my truck correctly and fix the PO hack job. I`m just going to do a flip kit in the rear and drop spindles up front with a 2" drop spring for a 4.5/6 drop. I`m planning on running this exhaust, http://www.summitracing.com/parts/ho...mc/model/c1500 Will I have clearance issues?
Anthony |
No idea on that summit system but here's a look at mine. TONS of room.
yeller
I had a 6" rear drop in my '73 with 3" exhaust...it went over the axle and around the rear fuel cell no problem.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
yeller
I'd love to see pics of the 7/9 drop...seems excessive unless you have removed the inner front/rear fenders or heavily modified the frame/suspension
My concern is the Hooked kit may be bent differently than a custom set up and won't clear.
Anthony |
driving is in my blood
No I've never had a exhaust shop give me a hard time. Sounds like a bad shop.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Cruzzzn' Vet
Mine dump right in front of the axle.
#15 |
I flipped the back of mine, 78 short step, with an aftermarket muffler. i wanted the pipe to come out the back, under the bumper, the muffler guy suggested it come out to the side, in front or in back of the back tire, but i said, naw...so he ran it out the back, under the bumper...the very back of the pipe might be a little flattened, but nothing serious that would affect flow.
#16 |
At the body shop.
![]() Dual 3" all kinds of room. Find another shop, they're lazy or incompetent
" That didnt make it any newer " " Dont antique the equipment " |
#17 |
You might get some flack from you muffler shop if they have to do any cut, fit and weld on that Aluminized pipe ! You can do it with slip fits and using a MIG welder .
#18 |
At the body shop.
I did remember that the metal brake line gets in the way of the right pipe, I've just bent it up parallel with the top of the frame rail.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 02-22-2016 at 07:53 PM. Reason: Spelling |
| Bookmarks |
