02-23-2016, 12:34 AM | #526 |
Re: D52 Caliper Rear Disc Brake Brackets
Ok thanks! Will do some measuring next time I'm out and I'll let you know. I think the brackets will fit but I'm. Pre worried about the calipers. I guess it all depends on how they will be clocked. I looked at the pics in the thread but it's hard to tell.
04-19-2016, 10:45 AM | #527 |
Got my "CaptainFab" brackets for my 69' stepside the other day. Machine work was excellent. I did not have any issues with fitment, everything lined up and went together perfect. Only issue I had was the pads were a little thick for the new rotors, I sanded the pads a little and caliper dropped in place then. Here is a couple of picks.....I put a coat of "POR" on the brackets....
04-19-2016, 10:48 AM | #528 |
Photobucket!!!!! Don't know what happened. anyway kit was great, Good Job Captain. Also, about the same time we had a 1963 c/10 at my repair shop for boost/mc add-on. We needed the bracket that mounts this set-up to the firewall. "CaptainFab" to the rescue once again. Bracket showed up couple days later and worked perfect......Casey
04-19-2016, 11:41 PM | #529 |
60-66 Nut
Thanks for posting your pics and the compliments Casey
04-25-2016, 06:07 PM | #530 |
04-25-2016, 11:52 PM | #531 |
60-66 Nut
I will send you a PM.
05-11-2016, 09:47 PM | #532 |
I would like to purchase a set of your brackets for my 77 c10 12 bolt. Please let me know how to pay and get them sent. Thanks
05-12-2016, 12:11 AM | #533 |
60-66 Nut
I'll send you a PM
05-13-2016, 10:24 AM | #534 |
Can you PM me a price for your black powder coated rear kit for my 1966 1/2 ton truck.
I don't have paypal i can mail you a money order or cashiers check. I will send it as soon as i get your PM. I already have your P.O. address
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-13-2016, 11:20 PM | #535 |
60-66 Nut
The price is exactly the same as in post #1 of this for sale thread. I will send you a PM.
05-18-2016, 01:28 AM | #536 |
Captainfab: I've got the d52 kit on my 72 c10. My issue is the outer brake pads are dragging the circumference of the rotor on the horizontal surface (hub?? Between the rotor face and the wheel.). Is there a certain set of brake pads you reccomend? Or did I install something wrong?
Posted via Mobile Device |
05-18-2016, 11:21 PM | #537 | |
60-66 Nut
How long ago did you purchase the D52 brackets? That issue arose quite some time ago, but I made a change to the caliper bracket to correct that.
05-19-2016, 12:03 AM | #538 |
Between December 2012 and March 2013.
05-19-2016, 12:44 AM | #539 |
60-66 Nut
I will confirm the date of the latest revision tomorrow, but I believe your brackets were before that. The interference issue is due to manufacturing tolerance differences in the aftermarket replacement rotors. Did you purchase the brackets in bare steel or satin black powder coat?
05-19-2016, 02:02 PM | #540 | |
05-20-2016, 12:11 AM | #541 |
60-66 Nut
I do not know of any specific rotors that are any different than others and no customers have let me know of any.
My latest revision of the caliper brackets was in October of 2014. So you do not have the revised brackets. If you will send me your shipping info, I will send you a set of the newest caliper brackets.
05-20-2016, 12:35 AM | #542 | |
05-20-2016, 12:37 AM | #543 |
60-66 Nut
OK. Hopefully those pads will stay in place up off of the rotor hat. If not let me know.
05-20-2016, 04:01 PM | #544 |
Payment sent for a set sir.
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
05-20-2016, 07:22 PM | #545 |
I have made a fatal mistake on my truck and cannot use your rear brake kit. My truck is a standard with a borg warner R10 overdrive which means my truck freewheels even with the truck in reverse and off. In other words I HAVE TO HAVE an e brake or my truck roles away in gear. I highly apologize and understand if you take some of the refund out for your troubles and fees. Please let me know if a refund is an issue. Again this is my fault and a public apology!
05-20-2016, 11:20 PM | #546 |
60-66 Nut
You apparently did not read page 1 of this for sale thread where the e-brake style of calipers are talked about.
05-20-2016, 11:28 PM | #547 |
Yes I read that but i do not want to use the caddie brakes. I have already purchased the D52's and now have to send the rears back as well. I dont want the mismatched brakes. To be honest it was more about looks than function for me.
05-21-2016, 12:15 AM | #548 |
He sells brackets for Camaro calipers as well which have e-brake.
1968 LWB C20 / AC / Wood Bed |
06-01-2016, 12:20 AM | #549 |
I just received mine . They really look nice. Thank you el capitan
07-16-2016, 07:47 PM | #550 |
Anything in the works for this same setup on a Ford 9"?
