Always a work in progress
73 Cab on 85 Frame
Which body mounts should I use?
73 or 85?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: 73 Cab on 85 Frame
I don't think it matters. Again, I think. The only thing that matters is that you use either the 2wd or 4wd mounts depending on what your building.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
Everything I've seen on the swaps is use the bushings that match the year of frame since the core support bushings are different
Diggin The SquareLife
Use the 85 mounts
| Bookmarks |
