Old 02-23-2016, 11:10 PM   #1
OldChevy61
OldChevy61's Avatar
Re: Lost My 65
Originally Posted by LostMy65 View Post
Started the FiTech install.
Bolting up and linkage are as simple as a carb swap.
I already had a spread bore manifold to square bore adapter plate, so I used that.
Some needed a riser at the air cleaner for some reason.
I didn't.
Also mocking up the Fuel Command Center.
Decided to mount it to the firewall.
Tell me more about this. Electric fuel pump required? What do you have to buy other than the fitech kit. Pm me total cost of this install if you don't mind. Thank you. Very nice work there.
OldChevy61 is offline   Reply With Quote
