Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 12-18-2015, 02:31 PM   #1
juddss
Selling Lsa Blower and adapter plates
I am selling my LSA CTS V supercharger and cathedral port to square port adapter plates. These plates will allow you to bolt this blower to any gen 3 or 4 4.8l 5.3l or 6.0 liter engine with cathedral shaped ports.
The blower has 30k miles on it and I have installed the new solid coupler.
Also comes with a throttle body adapter plate so you can bolt up any 3 bolt ls truck throttle body. It has a cable bracket on it so you can use a throttle body with a cable.
You would still need a intercooler lid, fuel injectors, heat exchanger, heat exchanger pump, and olson kustom works makes an accessory drive bracket that will allow you to use your factory truck drive accessories for $340. He also makes fuel rails for these with a return line. Run this with a walboro 450 lph fuel pump and good to go. All you will need is some tuning.
I am asking $900 plus shipping. You can call or text me at 315 430 0414 if you have any questions.
juddss is offline   Reply With Quote
Old 12-22-2015, 12:01 PM   #2
juddss
Re: Selling Lsa Blower and adapter plates
OK 850. Just thought id throw them up here before I put them on ebay.
Old 12-23-2015, 02:20 PM   #3
Kainedogg
Kainedogg's Avatar
Where did you source all the adapters? I have an LSA supercharger on my Chevelle and if I remove the drive by wire this may be an option.
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
Old 12-24-2015, 11:22 PM   #4
mrods72
mrods72's Avatar
Sent PM
mrods72 is offline   Reply With Quote
Old 01-05-2016, 09:08 AM   #5
Kainedogg
Kainedogg's Avatar
Sent you a PM Juds, unless it already sold on Ebay.
Old 01-07-2016, 11:31 PM   #6
juddss
Sorry the blower is sold. I got the throttle body bracket on ebay. It was made by LSX precision I believe.
Old 02-01-2016, 02:47 PM   #7
Kainedogg
Kainedogg's Avatar
Did the throttle bracket sell?
Old 02-02-2016, 10:04 PM   #8
juddss
All of it is sold. You can find those throttle body brackets on ebay for about 50 or $60
Old 02-24-2016, 12:40 PM   #9
Kainedogg
Kainedogg's Avatar
Thanks J.
