66 suburban 5.3 swap
I'm building a 66 suburban trying to put the 5.3 out of an 04 Chevy truck into it. I have the motor mounts figured out and I'm gathering up other parts for the swap. My question is and I know it has probably been asked a hundred times will the truck exhaust manifolds fit without doing anything to the frame or do I need to try and find Camaro manifolds or headers? I will only be lowering truck about 2-3 inches so ground clearance isn't an issue.
Re: 66 suburban 5.3 swap
From what i have read you can not use the factory truck manifolds without cutting/heating bending the frame. 1998-200? 2010 up camaro or trail blazer manifolds fit most swaps. Hooker makes swap manifolds that fit
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Aug 2004
Tbss manifolds work best for our trucks if you want sto stay factory lsx.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
what are tbss manifolds ?
tbss=Trailblazer SS
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Jul 2012
A friend built a 66 Suburban with the 5.3 and he used the Trailblazer SS manifolds.
i have personally used tbss manifolds and the hooker manifolds. Both worked out very well.
Has anyone used the shorty hooker headers?
Started the install of the 5.3 into the 66 looks like the ac compressor is going to be a tight fit in the lower position . Will it clear or is there another route to take looking for some ideas thanks
best to use the high mount.
I used Docs Blocks and trimmed the frame rail a tad. I don't know if Docs Blocks are used any longer. actually here they are. http://www.acsource.com/hoseblockhor...oringtype.aspx
![]() Join Date: Apr 2005
2010+ Camaro manifolds are da bomb....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#12 | |
https://www.holley.com/products/acce...y/parts/20-134 |
Thanks for all the replies I found a set of 2010 Camaro exhaust manifolds with the cats still on them locally. Tried them on and only had a small amount of clearance problem on motor mount nothing big. Decided to try and keep the ac compressor on the bottom for now and had to make a small notch on the frame. Tomorrow night maybe I can make the trans mount and get it all bolted in.
All right got motor and tranny in what are you guys using for a driveshaft. The orginal with the carry bearing or the driveshaft from the doner vehicle, I need all the help I can get here from someone who has done this before ,thanks.
