Old 02-23-2016, 01:41 PM   #526
toolboxchev
Re: Starting my engine build
Born Again, and looking quite well I may add.
toolboxchev is offline   Reply With Quote
Old 02-23-2016, 03:10 PM   #527
Mrturner1
Hey thanks man! I like it too. I've been doing some wire brushing and degreasing in the motor well. This part may take some time, I wouldn't want to stick this motor in there without it being just as nice
Mrturner1 is offline   Reply With Quote
Old 02-23-2016, 03:11 PM   #528
Mrturner1
Is it safe to pressure wash in the motor well?
Old 02-23-2016, 03:18 PM   #529
Mrturner1
Hard to believe it used to look like this
Old 02-23-2016, 11:14 PM   #530
Mrturner1
I'm also wondering about new energy suspension body mounts. I was under the truck today and they all look like squished cracked donuts, bulging out the sides from being so old. Definitely going with energy suspension motor and transmission mounts, and possibly replacing bushings on the major parts of the suspension.
I know I'm adding a lot of work but the more I look at the engine and compare to the motor well and wiring, the more I wanna do this right and be thorough
Old 02-23-2016, 11:40 PM   #531
swamp rat
swamp rat's Avatar
A little advice? Concentrate your energy on getting that engine back in and running first or it will go on forever.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-24-2016, 11:13 AM   #532
Mrturner1
I agree totally, I was just thinking that if there are things to do while the motor is out that would become a real PIA when it's back in, get those while the gettin is good
Old 02-24-2016, 11:14 AM   #533
Mrturner1
Anybody pressure wash without issues? All the grease and built up oil would be much easier with a pressure washer
Old 02-24-2016, 11:36 AM   #534
Mrturner1
Thank you I'm pretty excited about it
Old 02-24-2016, 12:28 PM   #535
BrianG
BrianG's Avatar
I see no reason why you couldn't power was the engine compartment. You have the Tranny out right? if not, just try not to get water in there, plus watch around your electrical connections. degrease it well, and spay away!
BrianG is offline   Reply With Quote
Old 02-24-2016, 07:01 PM   #536
Mrturner1
Well it took 2 hours to build all the MSD wires but I think the nicer look is worth the time. Waiting on de-greaser to soak in and then pressure washing.
Old 02-24-2016, 07:01 PM   #537
Mrturner1
Pic
Old 02-24-2016, 07:03 PM   #538
Mrturner1
Do you guys shave this extra RTV off or just leave it?
Old 02-24-2016, 09:10 PM   #539
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If you have headers... those wires will not work. You will need 90 degree boots to clear headers.
But they look killer though!
I have always built my plug wires while the engine is in the rig. Lots of stuff that will or could be in the way while figuring out the best route of plug wires.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-24-2016, 09:20 PM   #540
swamp rat
swamp rat's Avatar
I would leave the RTV on the intake, up to you i guess.
I agree with Gary on the 90 degree boots so guess you could bolt the headers up temporarily and see how they will work.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-24-2016, 09:36 PM   #541
Mrturner1
Well there goes 100 bucks and 2 hours
Old 02-24-2016, 11:07 PM   #542
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Not necessarily... http://www.jegs.com/i/MSD-Ignition/1...rentProductId=
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-25-2016, 12:28 AM   #543
Captainfab
60-66 Nut
Wait until you get the headers bolted up and see if maybe some of the straight plug boots will work. Then just change the ones that definitely need a 90.
Old 02-25-2016, 03:00 PM   #544
Mrturner1
I have some appointments at the VA today but hoping to get the motor well wrapped up by tonight. I pressure washed yesterday evening and was amazed at just how much crud came out and off the truck. After a little masking it'll be ready for some paint.
New motor mounts and a transmission mount will be here today. It looks like I could be firing this thing up pretty soon. For the first startup I'll have some zddp break-in oil, and I need to get a tachometer so I can manage the RPM's during cam break-in.
Technically I could start the truck after I get the new motor mounts and drop the motor in, and I suppose that's the shortest route to a start up. Without getting to absorbed into other projects just yet, I think it'd be wise to go ahead and get a stall converter now and be done with it. There's been a lot of controversy over what stall to run and who makes a good converter, and I can't say that I know what to go with yet, but I'd like to get one now so I can drive it after break-in and not fight the brakes and all that fun stuff.
Old 02-25-2016, 03:01 PM   #545
Mrturner1
Pic
Old 02-26-2016, 08:22 AM   #546
Grumpy old man
Grumpy old man's Avatar
I'm wondering now if you see why many of us suggested pulling the engine from the start ? You end up with a much better result for your effort and money and it looks better than if you paid someone to just drop parts in .How many small things did you find that really needed to be addressed ? It looks great and you should be proud of the work you've done ! And I don't give away compliments often ! That's why they call me Grumpy old man .
Now get it dialed in and running so you can move onto the suspension and brakes to make it safe to unleash those new found horses .
Did you get the right trans mount yet ?
Old 02-26-2016, 09:57 AM   #547
Davidf
A little time saving trick when you start masking: For hoses, lines and those little things you want to keep paint off of, pull out the aluminum foil and wrap the small stuff with it. Much easier than paper and/or tape. And, easy to remove as well.
Davidf is offline   Reply With Quote
Old 02-26-2016, 12:07 PM   #548
Mrturner1
Well that made my day, thank you very much that means a lot coming from a long time builder such as yourself I am actually pretty proud of this thing. And had I not pulled the engine it wouldn't be anywhere NEAR as nice as it is now. And the engine bay would be a greasy nasty faded mess with a mediocre looking motor in it, and I would be into it for 3600$ bucks by now not including all the transmission stuff I need. I'm still under 1500$ bucks and that includes some new tools and paint Doing it this way saved me a lot of money and helped me learn the things I need to know about my own truck. Before this I honestly couldn't have told you which cylinder was which, and I certainly wouldn't attempt to tune the truck (or know which way to tune it for what)
Prothane mounts should be here today for motor and trans, and I got a oem crossmember too
Old 02-26-2016, 02:15 PM   #549
Mrturner1
I apologize for the redundancy here guys but I want to clarify because I'm buying parts. The truck has a th400, so do I need to change the transmission crossmember to one like the peice in the picture? And when I get a trans mount, will the parts work for a th400 when the drop down bars on the online catalogs don't specifically say TH400, they only ask the engine size for application
Old 02-26-2016, 02:18 PM   #550
Mrturner1
Parts
