I need some pictures of where one of the braces for my brake booster bolts to the fire wall. It's the brace ( made of U channel steel) that mounts to the lower right stud on the master cylinder, and the other end ???. I bought the PB unit complete with all the brackets and braces, to put on my truck that came with non power brakes. When I put the unit on, everything mounted up perfectly, except this brace I'm asking about. I've seen the brace in some pictures but can't see where it bolts to the firewall. Did power brake equipped trucks have an extra hole in the firewall for this brace?
#2 | |
The Older Generation
Re: Where does it mount?
Here is a thread with some pictures. http://67-72chevytrucks.com/vboard/s...d.php?t=676183 LockDoc
![]() Join Date: Sep 2007
what year is your truck? 67-68 do not have the mount studs for the braces that i know of. neither of my 67`s have them
1967custom |
My truck is a 70. It came with non power brakes and steering, both of which I've added.
Thanks for the thread info. It shows me exactly what I needed to know. I don't have the lower mount hole on my firewall, so I'll have to drill one. It'll be easy, since id have my inner fender wells out right now. Thanks again Last edited by custom10nut; 02-23-2016 at 11:02 PM. |
#5 | |
No problem. Let us know if you need any more info.... LockDoc
Just some good info for all. If you're going to do the brake conversion from non to power, and you're using a donor set up, make sure you get ALL of the brackets and mounts, since to my knowledge, nobody makes them aftermarket
![]() Join Date: Mar 2003
More often than not, if you line up the bracket in the approximate area there will be a dimple in the firewall
Thanks, my plan is to loosely mount the top end, and see where it touches the firewall, and as you say, there should be a dimple for a mount. Again thanks for the info
![]() Join Date: May 2010
I don't believe those braces were used before 1971 along with disc brakes.
I put a nutsert in the firewall to mount the brace to
Sorry if I am hijacking this tread. I am doing the same swap on to a 68. Are the brackets really needed?
In LockDoc's attachment I see someone asked the same question with no answer. My plan was to run with out the brackets but maybe it is a bad idea. I do have the brackets but want a cleaner look.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
#12 | |
#13 | |
![]() Join Date: Jun 2005
I have had a booster on my truck for the last 8 years without the braces and have had no issues. I converted from manual to power, drum brakes. I don't think they are needed. I bought a set but never installed them, so I have a set if anyone is looking.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#15 |
Just a little additional info on these braces...
There were apparently 2 lengths of the U-channel brace based on those pictured below. As I recall, I got the longer one off a 3/4 ton in the junkyard and the shorter one off a 1/2 ton. Probably due to a larger booster for the 3/4. |
#16 | |
