Old 02-25-2016, 05:52 PM   #1
bean
Starter on a 305 with 1 terminal
Just dropped a later model 305 in the 72. Question is I had 2 wires going to 2 terminals on the 350... ,how do I connect them now we ith only one terminal on 305 starter? Can I just use my old solenoid or what? Thanks
bean is offline   Reply With Quote
Old 02-25-2016, 05:54 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Starter on a 305 with 1 terminal
Are you still using points ignition? That's what the yellow wire (relay) is used for.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-25-2016, 05:55 PM   #3
bean
No its got hei
Old 02-25-2016, 06:51 PM   #4
bean
So I can connect the other wire to the one terminal snd its good?
Old 02-25-2016, 07:09 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by bean View Post
No its got hei
Here's the wiring. The pink wire is where the purple goes and nothing goes to the outside terminal with HEI ignition.
BTW how did you wire the ignition to the HEI BAT distributor terminal?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-25-2016, 07:14 PM   #6
bean
Po wired it to fuse block. ThAnks for help
