![]() Join Date: Jul 2009
Steering column rebuild question
I'm about ready to install the column in my 78 GMC. While its still out I would like to deal with anything that is likely worn. It is a non-tilt column and I've got a 4-speed floor shift so this is a pretty basic column. I know that I want to replace the rubber boot on the steering coupler as well as the rag joint. I haven't had a chance to drive the truck enough to know whether there were other problems or not.
What would you replace while you were at it? Anyone with a good link to a column rebuild? Thanks
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
Re: Steering column rebuild question
ignition and safety neutral switches
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Thanks Chris. Is there actually a neutral safety switch in the column for manual transmission?
I am not sure how it works, but it may be hooked up to the clutch. Good luck. I took a 1977 straight, a 1979 straight - damaged, and a 1979 tilt - damaged, and combined to make a 1979 tilt. wow what a challenge.
So the ignition switch is the main thing to take care of while the column is out. Thanks for the suggestions.
![]() Join Date: Jul 2000
It's difficult, if not impossible, to adjust the switch once the column is bolted to the dash. GM did this intentionally to reduce the chances of theft. So be sure to check switch operation first.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Good luck trying to find the coupler boot. I couldn't find one at all.
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
I'd also clean and lube the top and bottom bearings. The grease tends to dry out over the years.
#10 | |
Thanks for the additional suggestions MikeB.
#11 | |
![]() Join Date: Dec 2012
thought I would post this
pretty good write up http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Anyone know whether our gen trucks have the 'key presence switch'?
My fasten set belt light stays on all the time, even with the vehicle off and the key out of the ignition. The senor on the retractor is not hooked up, but it still seems strange to me that it would stay lit even turned off and with the key out. |
Its been a while since I posted this question, but I did get the Jeep steering coupler boot. Came as a kit. The parts appeared to fit fine. The boot looks pretty good although I kind of mangled the plate in the base of the boot trying to get it over the pin in the shaft. I suspect that there is a better way to go about that job.
While I had the column apart, I ended up replacing the ignition switch, turn signal switch assembly and lower column bearings.
