Old 02-27-2016, 06:40 PM   #2
East Tex
Re: anyone have stock alignment specs?
I would set the toe straight up or 1/32" toe in, if I had all new front end parts. If you're dealing with old existing parts, I'd set it 1/32" in. Or if there were some play in the parts set it 1/16" toe in. As far as caster/camber, unless your front axle housing is bent, it probably won't need adjusting. But, if I were checking caster/camber (on a 4wd), I'd want to see the caster to be close to 0 on both sides (no more than 1/4 degree in or out). And I would want the passenger side caster to be the same as the driver side or maybe up to 1/2 degree more.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
1972, alignment specs, blazer, factory, stock
