Closed Thread
Old 02-28-2016, 09:14 PM   #3301
sportside
Re: What did you do to your truck today? Chapter II
I installed a tach/vacuum cluster, floor shift tilt column, steering wheel and buddy buckets.
sportside is offline
Old 02-28-2016, 09:46 PM   #3302
flashed
The gauge cluster and BuddyBuckets look great .
flashed is offline
Old 02-28-2016, 09:51 PM   #3303
Security guy
Security guy's Avatar
Painted my wheels and got some new rubber installed...
Security guy is offline
Old 02-29-2016, 09:35 AM   #3304
73737373
Originally Posted by New_70'C10 View Post
Hey 73737373, is that your permanent plate or is that just for show on your bumper there? If so how did you get it registered with the original plate?
Thanks,
Charles.
OK will allow you to use an old license plate. You have to get a "real" tag and keep it in the truck w/you. It costs $21.50 to use the old one.
73737373 is offline
Old 02-29-2016, 09:38 AM   #3305
73737373
Originally Posted by 89AKurt View Post
Never heard of this before, thanks! Better than Coke, no sugar.
This was getting messy, and scary....
Much better, and new rubber brake lines too.
Nice. Go to their website and they'll let you post before/after pics. I sent them some a couple weeks ago, but haven't checked the site.
73737373 is offline
Old 02-29-2016, 10:56 AM   #3306
73737373
More pics.... Was quite a bit of decay along the bottom of the skin so had my upholstery guy sew a strip along the bottom. I thought the mismatching colors was better than a ragged finish.
I glued the skin to a metal door panel. The wrinkles are from where the foam separated from the vinyl and I did not peel all that off from the backside of the skin to reglue it. I did it on the driver side door skin, and it's a miserable job. There's the vinyl, the foam and then the paper, and the foam/paper is heat sealed to the embossed areas on the door panel. Hard to explain.
I need some matching color estucheons!!
73737373 is offline
Old 02-29-2016, 11:06 AM   #3307
73737373
Hood. Not sure if I'm going to be able to save it, or have to get it repainted..... I did the passenger side and it came out OK. The spots that have paint on them shine like new. Found myself buffing a lot of black primer to a shine.... Very delicate balance to get the dead paint off to find some that I can work, without going all the way to the bare metal.
73737373 is offline
Old 02-29-2016, 11:13 AM   #3308
73737373
Rear sport bumper. Patina truck needs a patina bumper, although am toying w/putting a new one on.
My little helper in the lower left on the 1st picture.
73737373 is offline
Old 02-29-2016, 11:17 AM   #3309
73737373
And redid a wheel... Lots of sanding, some SEM primer, more sanding and Rustoleum professional gloss white. Magic!!
73737373 is offline
Old 02-29-2016, 12:27 PM   #3310
Jose's 69
Started my front suspension rebuild and disc brake conversion.
Jose's 69 is offline
Old 03-01-2016, 08:51 PM   #3311
vidman
vidman's Avatar
Installed my dash-pad and did some interior wiring
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 03-01-2016, 09:17 PM   #3312
firedemon
a little further today
firedemon is offline
Old 03-01-2016, 09:23 PM   #3313
tlman
Thumbs up Re: What did you do to your truck today? Chapter II
waiting for rad support to test engine ,hasn't been run yet, drive shaft coming checked out wiring harness .gotta paint headers ,but I'm gonna take a break tonight
tlman is offline
Old 03-02-2016, 09:50 AM   #3314
midniteblues
midniteblues's Avatar
Finished these up yesterday. I didn't notice they screwed up and gave me 3/4" bolts for the hooks gotta go back and get 5/8".
The knob on the hubs has some pits in them that took black paint when I sprayed the letters. they look good enough 4 me.
Wrap m box m and on the self they both go for a while till I'm ready for them.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 03-03-2016, 04:55 PM   #3315
OregonNed
OregonNed's Avatar
Polishing up my bed strips in anticipation of the new boards
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-03-2016, 05:57 PM   #3316
73737373
Just about the prettiest thing on these trucks is a refinished wood floor bed w/the stainless strips.
73737373 is offline
Old 03-04-2016, 09:33 PM   #3317
firedemon
not a lot but dash is done
Old 03-05-2016, 12:25 AM   #3318
89AKurt
89AKurt's Avatar
Replaced the transmission mount. Some of you might get a kick out of my sophisticated "shade tree mechanic" jack.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline
Old 03-05-2016, 01:44 AM   #3319
Metaldoc
Metaldoc's Avatar
new booster, master, proportional valve, brackets, and lines, lines and brackets from scratch.
Metaldoc is offline
Old 03-05-2016, 01:51 AM   #3320
OregonNed
OregonNed's Avatar
Almost done with the strips
Old 03-05-2016, 01:53 AM   #3321
OregonNed
OregonNed's Avatar
One more
Old 03-05-2016, 01:54 AM   #3322
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I REALLY like it.
It stumps me, though.
Then again, I'm pretty loggy tonight.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-05-2016, 02:59 AM   #3323
toolboxchev
I am kinda stumped by that comment also. That more conventional that anything I know.
Woodnt know any other way to get things done.
toolboxchev is offline
Old 03-05-2016, 04:03 AM   #3324
89AKurt
89AKurt's Avatar
You guys crack me up.
1968 Long Bed
89AKurt is offline
Old 03-05-2016, 06:55 AM   #3325
doo142
doo142's Avatar
Got Rusty's cab markers glowing . Cleaned, greased, bulbs, replaced lenses with mo betta oem ones.
72 Cheyenne k/20, Custom Camper
72 Cheyenne k/20
71 blazer K/5 2WD 454, 6 sp.
67 Chevy Napco c30 Dump
56 GMC Napco 4x4 short step
66 Chevy K10
68 Chevy C/30 4x4
doo142 is offline
Closed Thread
