Old 02-29-2016, 04:18 PM   #76
RockinKees
RockinKees's Avatar
Re: Plus Five
Originally Posted by donandal View Post
Thank you,
Yeah,
There is a manual disconnect.
Battery is under the floor passenger side.
If you look at the last picture in post #64, at the bottom below the lower
Pivot arm there is a knurled knob. On that linkage there is also a pin that
can be pulled ( after you release spring tension by twisting the knob counterclockwise)
that will allow manual opening of the hood. It's a little
heavy, but my wife can do it easily by herself.
When you lift manually, once it goes over center weight wise, it will fall to
the full open position. The springs on the limit rods catch it smoothly.
I did spend a lot of time figuring the linkage geometry of that lift actuator.
My calculations were pretty close though, so it didn't need to be reworked
too much after I tried it with scrap materials.
Thanks for the info.
I was wondering, and what I said: really nice work!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-29-2016, 05:28 PM   #77
69CST-V
69CST-V's Avatar
Re: Plus Five
Incredible fab work... Like where you are taking it. Keep posting
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 02-29-2016, 05:49 PM   #78
II_Slow
II_Slow's Avatar
Re: Plus Five
Didn't know just how bad/crude my fab work was until I saw yours. Suddenly I'm feeling a little inadequate.....
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 03-02-2016, 02:28 PM   #79
donandal
Re: Plus Five
I made the inner fenders from 18 gauge steel. The hood
frame closes against a strip of aluminum attached to
the fenders that will not be painted. A rubber weatherstrip
on the frame will seal it up.
I used a bracket at the firewall similar to the original Z channel
to space the inner fender about an inch away from the firewall.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-02-2016, 02:44 PM   #80
donandal
Re: Plus Five
I also made covers that go over the inside of the
A-arms. They cover up the A-arm pivot area and
will keep spray from coming in from the wheel well.
You can see some of them in these pictures.
53 Chevy Pickup
Old 03-02-2016, 02:58 PM   #81
Chance48
Re: Plus Five
Beautiful clean work as usual man!
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 03-02-2016, 03:51 PM   #82
donandal
Re: Plus Five
That covers most of the chassis and cab basics. The details
will be posted later in the finishing process.
This is how I finished the front end.
I tucked the bumper in a little closer to the fenders. It's
just a stock front bumper. the bumper and valance tilt
with the hood.
53 Chevy Pickup
Old 03-02-2016, 03:54 PM   #83
donandal
Re: Plus Five
final look...
53 Chevy Pickup
Old 03-02-2016, 04:04 PM   #84
donandal
Re: Plus Five
the rear is just a front bumper cut into two
sections. I used a stainless steel one so I could cut
it down and polish the edge. No chrome needed.
The center folds up for trailer hitch access. Stainless
steel spring pins hold it open or closed.
53 Chevy Pickup
Old 03-02-2016, 04:16 PM   #85
donandal
Re: Plus Five
parts for the rear valance...
53 Chevy Pickup
Old 03-02-2016, 04:21 PM   #86
donandal
Re: Plus Five
I made these filler pieces behind the fenders,
53 Chevy Pickup
Old 03-02-2016, 04:28 PM   #87
donandal
Re: Plus Five
I also made new side panel filler pieces...
53 Chevy Pickup
Old 03-02-2016, 04:33 PM   #88
donandal
Re: Plus Five
I made a little die to press out some extensions for the stake
pockets.
53 Chevy Pickup
Old 03-02-2016, 04:40 PM   #89
donandal
Re: Plus Five
and capped off the ends...
53 Chevy Pickup
Old 03-02-2016, 05:09 PM   #90
Iplumb
Re: Plus Five
Very Very Nice.
You are truly a craftsman.
Mike
Iplumb is offline   Reply With Quote
Old 03-02-2016, 05:27 PM   #91
mongocanfly
mongocanfly's Avatar
Re: Plus Five
I've been watching this one..easy to tell this isn't your first one..very nice work and attention to details..
Old 03-02-2016, 06:20 PM   #92
torchlight
torchlight's Avatar
Re: Plus Five
Absolutely love the front bumper tuck! I appreciate the subtelty of it. Very custom, but it looks like it could have rolled off the factory line that way.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 03-02-2016, 10:05 PM   #93
youngrodder
youngrodder's Avatar
Re: Plus Five
Great metal work. You make it look soooo easy.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-02-2016, 10:16 PM   #94
Advanced Design
Advanced Design's Avatar
Re: Plus Five
There are so many nice details in your build that are extremely well done. I like the stake pocket extensions, and the end caps, and the ... Thanks for showing all the details.
Advanced Design is offline   Reply With Quote
Old 03-03-2016, 10:54 AM   #95
69CST-V
69CST-V's Avatar
Re: Plus Five
Very nice fab skills...Thanks for sharing.
Bryce
Company Trucks
Old 03-03-2016, 10:58 AM   #96
RockinKees
RockinKees's Avatar
Re: Plus Five
Eye for detail is short said....
Would you be so kind showing how you did the hinges on the licenseplate, between the rear bumpers??
Thanks for sharing!!
Cheers!! Kees.
Kool Guyz CC
Old 03-03-2016, 11:46 AM   #97
oldman3
oldman3's Avatar
Re: Plus Five
What can I say, just beautiful work...Jim
oldman3 is offline   Reply With Quote
Old 03-03-2016, 01:34 PM   #98
donandal
Re: Plus Five
yeah,
I'll have to get some pictures of the hinge and latch pin setup.
I don't remember if I took any yet.
53 Chevy Pickup
Old 03-03-2016, 01:37 PM   #99
donandal
Re: Plus Five
Thanks everyone,
I really appreciate all the comments.
53 Chevy Pickup
Old 03-03-2016, 04:46 PM   #100
donandal
Re: Plus Five
So,
I think I've covered most of the rear bed,fenders etc.
I do want to mention MAR-K quality truck parts. I bought
all of my box parts from them, and they are excellent.
Service and shipping were great.
It saved so much time using their new parts I think it saved
me money as well! Great products!!!!!!
I planned a different type bed floor, so ordered my bedsides
without holes or angle strip welded in place.
They have options already in place to custom order your box
parts and mine came exactly as ordered.
I wanted something sturdy, maintenance free, and different.
I drew up a sketch of a flange and C-channel shape and had a local
sheet metal shop bend them up for me. I stayed shy just a little
from the sides, and installed a L-shaped bracket to tie it
together and fill the gaps.
It is .080 brushed stainless steel. I made recess and dimple dies
to mount the screws and bolts. There are a ton of bolts that hold it
together and hold it down to the frame cross members.
I'll peel the plastic wrap of later.
53 Chevy Pickup
