03-03-2004, 09:19 PM | #1 |
Wheels needed
I need some 15x10 or 15x12 wheels to mount my new boggers on. Prefer some thing cheap as they will only be on for short periods.Chrome ,white or aluminum it doesn't really matter as long as theyre not bent . The cheaper the better! Shipping will be to 39057.
Also, Is any body running 35's with 4in.of lift. Mine doesent look like it's gonna clear them. I looked at an 86 with 4in. and 35's and it seemed to clear them better than my 33's with 4in.. Any thoughts? Thanks, Jeff
EXPERIMENTAL STAGES OF SANITY _____________________________ Run whatcha brung, and hope you brung enuff |
03-03-2004, 10:12 PM | #2 |
user # 2756
Which 35" boggers? Don't they have 2 different sizes like a 16" wide and a 14.5"? If it's the 16" wide then I'd say you need at least 6" of lift. The 14.5s will be close with 4", are you doing straight line mud bogging? A lot depends on how much you'll cycle the suspension.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
03-03-2004, 10:31 PM | #3 |
I wussed out and got the 14.50's . The suspension will need to flex a fair amount but nothing extreme. By the way the wheels need to be 6 hole pattern .
