Old 11-21-2015, 01:23 AM   #1
Local29
Starting my 65 C10 Build... Need parts/info/input/ect??
Hey Guys,
Newbie here, just starting my build now that i saved up a few extra coin. Kinda going for a budget build in time for my wedding in June. But i have a bit of learning/work to do to get there. I also get to do this while sitting down the hole time so it should get interesting. (had a bit of an accident that left me in a chair but i got skills i have a good platform to start from, basically a stock 65... except the motor, grill, rims & paint. maybe the wiring harness, interior ect..
Truck as it sits;
65 c10
Motor- Caddie 8.2 500ci
Rest is stock
To Do List;
Motor Mounts (current ones are a joke (HSS1/2"x3"x1/8" stacked 5-6 high, lol need to draw and make a new set since i'm sure they don't make it)
Power brakes
Disk Brakes w/ drop spindles (hope to buy in a set)
Power steering
Air Ride
Maybe Relocate Gas Tank
Little Electrical Issue (blinker draw)
C Notch Frame maybe?...(trying to sit the frame without loosing so much bed, i still wanna use the bed but be able to get in it easy)
design hand controls since current sets don't really work on this year besides the portable sets..
Also all the little things that go with each item & little issues.. (brake/steering/fuel lines, brackets, carb, wheels/rims, gaskets(exhaust manifold, tranny are leaking oil(little weird for the exhaust tho)
Future work;
Paint
Interior
Relocate Gas Tank
Bed
Found this deal so far;
Front Disk Brakes/Spindles
http://www.ebay.com/itm/63-70-CHEVY-...1V15Rn&vxp=mtr
Anyone got any input?
Air ride, got any tips?
What rims will work with disk/drop spindles?
Motor Mounts?
Converting the Caddie power steering pump with Chevy box?
Local29 is offline   Reply With Quote
Old 11-21-2015, 02:22 AM   #2
vdawg
vdawg's Avatar
Re: Starting my 65 C10 Build... Need parts/info/input/ect??
Welcome and nice truck.
US Army Veterano
vdawg is offline   Reply With Quote
Old 11-21-2015, 12:57 PM   #3
62stepside longbox
62stepside longbox's Avatar
Welcome. Liking the 62 grill
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-27-2016, 08:54 PM   #4
Local29
Well haven't touched back in a bit.. but parts came in and i've been a little busy!!
Old 02-27-2016, 09:08 PM   #5
Local29
Here are a couple more
Old 02-27-2016, 09:59 PM   #6
Local29
I got some good helpers
Old 02-27-2016, 10:00 PM   #7
urmyboyblue
If you haven't already figured this out, if you have a Caddy power steering pump that is on the motor, just convert to a power steering gear box and buy some hoses to plumb them together. Should work like a champ.
urmyboyblue is offline   Reply With Quote
Old 02-27-2016, 10:11 PM   #8
Local29
Yeah that's what i figured.. my only worry was/is if the fittings are the same size but just ordered the hoses for the c10 box, so i will find out soon!!!. If not I'm sure they make a adapter fitting or something..
Old 03-01-2016, 12:36 PM   #9
Local29
Tank &n compressors mounted, lines ran.. Now just got to wire it up!!
