Old 03-01-2016, 12:42 PM   #1
Metaldoc
Metaldoc's Avatar
Re: rear outer wheel well question
I use 19 ga steel and bend it on my table edge. 1 inch thick solid steel 22"x33" table top. The edge of the wheel well I bent with a bar, 1/2 " deep cut as shown in pic. I cut the old well out and used it as the template. I drilled holes to spot weld the upper edge, fit it under the bottom on the well and tacked that edge together.
Metaldoc is offline   Reply With Quote
Old 03-01-2016, 08:48 PM   #2
vidman
vidman's Avatar
I think i used 18 gauge on mine. been 2 years now, and used 2 pieces on each side and welded them together..My buddy runs a hot rod shop, so he has all kinds of good stuff laying around.....
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
