Old 03-02-2004, 02:29 PM   #1
Trucks
Is that a Chevy 69...?
need new rearend +
New member here
Hello, I have a 68 GMC 3/4 ton 4x4 that has 4.56 gears, tooo low and also the rear end is damaged and needs replaced. I am looking for a set for front and back of something in the 3.08 range for gears. I hope to find some bolt on parts such as a whole tube from tire to tire, but what ya got? 1/2 ton ok, will trade my parts as well.
Located in MN - 55312 Thanks!
Ahhhh, the wonderful sound of a rumbling V8.
Trucks is offline   Reply With Quote
Old 03-02-2004, 10:00 PM   #2
Trucks
help
anyone got advice? heres more questions...How high would I want to rev a 250 I6 at freeway speeds for hours, 3200 ok? How about a 350cu in, 3200 ok?
Old 03-02-2004, 10:43 PM   #3
whitesswj
Embrace the Redneck
whitesswj's Avatar
i know that my 250 does fine at 3200. and i might have a rear end but it isn't posi and i want to think that it is 3.73. No sure. but i know it's 3.something. sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-02-2004, 10:51 PM   #4
Trucks
well
I6 is whats in it, if i can do 65 mph at 3200rpm maybe I'll be ok with 4.56's. I got my stats from the site
http://richmondgear.com/streetcalculators.html
Old 03-02-2004, 11:05 PM   #5
whitesswj
Embrace the Redneck
whitesswj's Avatar
thats what i have in mine a 250 I6 4.56 rear 3 in the tree. i think i'm fine. but it does suck the gas. i can do about 75 at 3400.
'01 Camaro
Old 03-02-2004, 11:43 PM   #6
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Talking 3/4 ton rear
Trucks, if you want to go to a 3.07 rear you will have to use a Dana 61 rear. Later Willis
67-72williso is offline   Reply With Quote
Old 03-02-2004, 11:49 PM   #7
67-72williso
Old 03-02-2004, 11:50 PM   #8
whitesswj
Embrace the Redneck
whitesswj's Avatar
willis i suppose you're saying that the 4.56 is a 3/4 ton?
'01 Camaro
Old 03-03-2004, 12:27 AM   #9
67-72williso
Yes I beleive that is what trucks is talking about. Read the original post. Later Willis
Old 03-03-2004, 01:37 PM   #10
Trucks
yep
ya its 3/4 ton, does that matter?
what about a 350, should they run @ 3200 on a freeway?
looking at keeping my front and getting another 4.56 from a yard then. What kind of milage did you get with your I6? 13mpg? 10?
I have a 350 in a 2wd that gets 15 average but it might be 4.11 gears.
Old 03-03-2004, 01:45 PM   #11
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Trucks... I'm a little speed demon and I turn my 327 at 3000 for hours when traveling. I have 3.08's and that puts me at ~80-83mph (th350 tranny). I will get ~12mpg at this speed. I don't see a problem at all for turning a 350 at 3200, and don't see one if your spinning the 6 at the same speed... WIND IT UP!
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 03-03-2004, 11:22 PM   #12
67-72williso
Talking 3/4 ton
Trucks,4.56 ain`t very good highway gears. A 3.07 Dana 61 would be much better. The Dana 44 front would only need a gear change. Work involved but worth it. I`m running a Dana 61 with 3.07 and locker in my 70 C-20. Later Willis
