Old 03-01-2016, 11:34 PM   #1
btirvin
1970 K2500 8 lug track width
Guys,
I'm looking to swap a later disc brake Dana 44 under my 1970 with drum brakes but I can't seem to find the track width on the front end. I know '73 and later are 65.8" but I would like to know what the track width on the 1970 is before I pick up a new diff. Anyone have that measurement?
btirvin is offline   Reply With Quote
Old 03-02-2016, 11:25 AM   #2
Mike C
Mike C's Avatar
Re: 1970 K2500 8 lug track width
No, but it shouldn't have any real bearing on the swap. The disc setup is a little wider if memory serves, but you shouldn't have any issues unless you have a REALLY tight wheel/tire clearance right now.
The added clearance to the leaf springs when the wheel is turned is usually welcome.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-02-2016, 11:55 AM   #3
btirvin
Thanks Mike C,
I know the disc front end works great on my '72 GMC K2500, but it came stock on it. I'm just trying to find out if the '70-'72 front ends are the same track width as the '73 and later so I know what I have. I can put a tape measure to either the '70 or '72 but both have aftermarket wheels and they may not have the stock offset.
I just find it curious that I can find original track width dimensions for Fords, Dodge, Jeep and '73 and later Chevy/GMC's, but I can't find track width on the '70-72 model years with 4WD.
I have many books on these trucks but can't seem to find it in them either. If anyone knows, I would love to have the dimension. Thx.
___________
'72 GMC K2500
'70 GMC K2500
