Old 03-02-2016, 10:59 PM   #601
Mrturner1
Re: Starting my engine build
PUTTING IN ALL THE FLUIDS AND STARTIN HER UP!!!! I'll take video
Mrturner1 is offline   Reply With Quote
Old 03-03-2016, 02:04 AM   #602
Mrturner1
It started!!!!! Ran like a champ but the belt was screaming. New pulleys aren't lined up properly so tomarrow ill have to get a new belt and figure out a way to make the puppy's all line up.
BUT IT RAN!!!! Woooooohooooo I built a motor that works!! And it sounds so much more badass than it used to. The bump in compression made a huge difference. I'm not gonna be able to sleep tonight but I'll be at it again tomarrow
Old 03-03-2016, 02:59 AM   #603
swamp rat
swamp rat's Avatar
Just don't get so pumped you forget to go straight into break in mode when you do fire it up.
Maybe post straight from the side pictures of what is not aligned properly. New pulley's? aftermarket? Yea that can be a problem, there are shims available for the crank pulley, maybe water pump, that is if the pulley needs to be spaced away from the engine..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-03-2016, 03:00 AM   #604
swamp rat
swamp rat's Avatar
Hey i thought you returned that chrome alternator.... Maybe that was the water pump..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-03-2016, 03:16 AM   #605
Mrturner1
I shimmed the water pump to line up perfectly with alternator, now it's just the crank pulley. It to far out though and has no shims so I don't know how I'm gonna get that to line up right. They are polished aluminum aftermarket pulleys. I'm so excited!!!
Old 03-03-2016, 03:17 AM   #606
Mrturner1
It was the water pump lol alternator was cheap from this sites classifieds
Old 03-03-2016, 01:04 PM   #607
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Is that your temp sending unit in the intake on the front passenger side? I'd put it where it belongs in the drivers side cylinder head, and reroute that heater hose to the passenger side front intake.
Not to nit-pick, but it will look way better too, so the hoses aren't stretched over the front of the engine.
Like this:
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-03-2016, 04:20 PM   #608
swamp rat
swamp rat's Avatar
This is why i hate aftermarket pulleys Unless you buy a system where they are all designed to work together, every aftermarket pulley i have looked at at the auto parts store's always have alignment issues when mixed with stock stuff..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-03-2016, 06:50 PM   #609
Mrturner1
Like this:
Gary
Is the temp more accurate in the driver side head? Cleaner would look better, I just need a plug for the intake
Old 03-03-2016, 06:51 PM   #610
Mrturner1
I'm working on shimming the alt pulley and water pump pulley OUT to match the crank pulley. Got a new belt and I'll try it again
Old 03-03-2016, 07:33 PM   #611
68c10owner
68c10owner's Avatar
I see no mention of any break in of the camshaft. Please tell me you didnt just fire it up and let it idle.
Anthony
68c10owner is offline   Reply With Quote
Old 03-03-2016, 10:42 PM   #612
swamp rat
swamp rat's Avatar
No he knows about the break in procedure, but he has threads allover the board so its hard to keep track.
He said he had a 10 minute run and had to shut it down because the belt broke, but will start the procedure over upon refiring the engine.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-03-2016, 11:06 PM   #613
Mrturner1
Got the pulleys lined up and new belt on. Fired right up and ran it at 2100-2500rpms for another 20 minutes. Then I turned the idle UP to about 3000 rpm and put a timing light on it. It was way about 11 degrees off. Unplugged the vacuum advance on the distributor, and set my timing dial to 36, turned the distributor a bit advanced until I was at 0 on the timing tab and it started running MUCH nicer. No pops, hiccups or backfires now and I re plugged the vacuum advance. Idled down to 850, and it's ABSOLUTELY NASTY. That 280H comp magnum is a beast! The bump in compression made a nice improvement as well.
I'm playing with the 650 AVS carb still. Two screws on the front, left is idle mixture screw correct? What should that be set at? Left screw is what? And Edelbrock masters out there.
One thing I noticed is MUCH faster throttle response which I didn't expect but really really like. No studder when you stab it fast and it revs way faster than it used to. This thing honestly is NOTHING like it used to be, and I'm so glad I listened to advice and went ahead with pullin the motor and doing it all thorough and right, it really paid off big time.
I'm no computer genius but I'm working on videos. I have the first three tries that died due to timing. And I have one where I got it dialed close enough and ran it. I also have an idle and rev video after it was all times right with a gun and light. Any body help with video posting?
Old 03-03-2016, 11:10 PM   #614
68c10owner
68c10owner's Avatar
You are going to want quite a bit more initial timing. 0 degrees is for stock engines. You will want about 12-16 initial with 36-38 total. You may have to play with the weights and spri gs to get the curve right.
Anthony
Old 03-04-2016, 12:30 AM   #615
swamp rat
swamp rat's Avatar
Both the screws in the front are air fuel adjust screws, one supplies one bank the other supplies the other bank, they should be roughly 2 to 2 1/2 turns out from lightly seated (meaning "lightly" bottomed, then backed out) Idle should be about 700, turn one air fuel screw in slowly until the idle gets a little rough then back it out about 1/4 turn, do the same on the other screw. Thats a good starting point.
I am a bit concerned about your timing tho as mentioned above.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-04-2016, 12:37 AM   #616
Valarius_Starchaser
Valarius_Starchaser's Avatar
Congrats on building your first engine man! Now all your friends will come to you with "I have this such and such problem with my so and so car." I have been quietly listening without much to add or say.
One thing I must say is I'm really impressed by how many just jumped in and taught you how to do it right the first time thats what I love about this board everyone just wants to help another guy out simply because we all love these trucks
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-04-2016, 01:02 AM   #617
Captainfab
60-66 Nut
It sounds to me like he set the timing at 36* @ 3000.
Old 03-04-2016, 01:11 AM   #618
68c10owner
68c10owner's Avatar
Yeah but did you read the part where he said he put the timing mark at 0 and it started running better? 0 initial timing will make this thing a dog regardlessof what his timing at 3000 rpms is.
OP, did you do a full rebuild or just a cam and head swap? Not trying to bust your bubble, just trying to follow along. While a cam and head swap is a huge deal for a newbie, and sounds like you were successful, its not technically a rebuild.
Anthony
Old 03-04-2016, 01:24 AM   #619
Mrturner1
Cam lifters and heads
Old 03-04-2016, 01:25 AM   #620
Mrturner1
I don't know how to tell what timing is in the distributor
Old 03-04-2016, 01:31 AM   #621
68c10owner
68c10owner's Avatar
With the truck idling disconnect the vacuum advance and put the timing light on it. The ti.ing tab will tell you your initial or base timing. You want to advance it so look at the BTC numbers. It will run much better once you get the timing curve dialed in.
Anthony
Old 03-04-2016, 01:55 AM   #622
Mrturner1
How much initial or base do I want? And is initial set with dial on "0"
Old 03-04-2016, 02:12 AM   #623
68c10owner
68c10owner's Avatar
See my post above
Anthony
Old 03-04-2016, 02:16 AM   #624
Mrturner1
See my post above
So is that 12-16 BTDC with the dial on "0"?? I read that the dial should be set at 36 and then get the mark on the balancer to 0 to have 36 total. But I don't know for initial
Old 03-04-2016, 02:18 AM   #625
Mrturner1
I put the timing MARK at "0", the dial on the timing gun was at 36. So if the dial is at 36, you want the timing Mark to be at 0 to actually equal 36
