Old 03-03-2016, 12:12 AM   #1
Mrturner1
What screws in passenger side of block?
I was filling up with water to start new build and water came out this hole. Can somebody tell me what goes here? And what size, it's really close to the header flange so does it thread in past flush with the block?
Mrturner1 is offline   Reply With Quote
Old 03-03-2016, 12:26 AM   #2
60case
Re: What screws in passenger side of block?
Hole is for temp sender. Looks like 3/8 pipe thread
60case is offline   Reply With Quote
Old 03-03-2016, 12:35 AM   #3
71swb4x4
71swb4x4's Avatar
You can plug it if you aren't using it. Well that's kind of silly for me to say, I guess you either plug it or you ride around on the core support pouring more water into the radiator as you drive down the road.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-03-2016, 09:32 AM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: What screws in passenger side of block?
I believe that's 1/2" pipe threads on those holes...
Ben
snipescastle2 is offline   Reply With Quote
Old 03-03-2016, 11:04 AM   #5
chiefcfd
chiefcfd's Avatar
Passenger side hole is a plug only. Temp sensor should be on drivers side. Mine has female hex head plugs.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 03-03-2016, 07:18 PM   #6
hugger6933
Get those plug wires off the header before you ruin the MSD wires and your day. Jim
hugger6933 is offline   Reply With Quote
Old 03-03-2016, 07:39 PM   #7
swamp rat
swamp rat's Avatar
Temp sensor installs on driver side, NPT plug on passenger side
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
