#26 |
![]() Join Date: Jun 2013
Re: RIDETECH Coilovers on a 73-87
The coilovers are height adjustable. The HQ version also has adjustable rebound dampening.
#27 |
How much of an increase is it to get the HQ version? Also how much caster do the control arms add?
#28 | |
#29 |
yes sir.. I want to go with rack and pinion
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
#30 |
Got a rear coilover setup for the rear?
#31 |
your coilovers coupled with rack n pinion will make the truck handle nicely..thats what im after.. ive installed your kit in a 68 and installed the unisteer kit and it handles like a dream.. but im not a fan of the looks if the unisteer kit..i don't like that arm that sticks out..
#32 |
Im working on this 67 right now..see tht arm that sticks up.on the driver side...i domt like that..with a built crossmember i wont have that... but i gotta say your coilover kit is pretty sweet..
#33 | |
Also, the arms are designed to set the caster at 5 Degrees. |
#34 |
Not a bolt-in one yet for the square fender trucks, but we do plan to do one in the future.
#35 |
Your Frame is looking good!
#36 |
#37 |
#38 |
Excuse my ignorance on coil-over setups, but do these require a sway bar as well?
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
#39 |
It doesn't require a sway bar, but I always suggest using at least a front sway bar.
#40 |
You don't have to have a sway bar but you will have a much better ride with one. Here is my 75 with Ridetech coilovers on the rear and front. First time attaching a pic here goes...
[ATTACH][ATTACH] |
#41 |
I like your sway bar location.
#42 |
Thanks. It made sense for this application on the '75 frame and the diff brackets. One bracket for coilover mounts, bars, and swaybar.
#43 |
Hafton-- which upper/lower control arms do you have? Stock crossmember? What 4 link is this? Thanks
#44 | |
1976 C-10 Stepside 2005 Chevy Avalanche Z71 2008 Subaru Wrx - Modified Track Car 2012 Harley Davidson Fatbob Custom My build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703077 |
#45 |
The PorterBuilt parts are some very well built parts! I used a PB Dropmember on of my C-10 builds a few years back. You can get Ridetech Q-series shocks or Ridetech Coilovers on any of their suspension kits.
#46 |
Here is a question for you, does Ridetch make Fox Shocks or does Fox make Ridetech? I was under the impression that they were 2 separate companies. My Ridetech Coilovers have Fox logos on them.
#47 | |
So I guess the best answer is both! |
#48 |
I know this is an older posting, but I just finished my 1971 GMC with the ridetec coil overs and the Rack and Pinion for No Limit Engineering. played a bit on alignment but it handles great.
#49 |
Are parts available separately?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#50 |
The coil over kit and coil overs themselves are separate. I got them from Jegs
