![]() Join Date: Jul 2008
Need help with 68-72 stepside longbed fender with spare tire cut out
Hey everybody, I posted this on the parts board and have had some good help, but have not come up with what I need just yet. I need a driver's side fender with the cutout for the spare tire for a longbed 68-72 truck. There is a difference between the shortbed and longbed fender - the cutout areas are different. I know this is a hard to find part, so I hope that someone out there has one or knows of someone who has one to sell. I need it in order to finish my 15 year long restoration......I'm so close! The pic below shows the fender that I need. Thanks! Dave
Dave R. 1972 K20 1972 C20 Highlander 1967 C10 1972 C10 |
Re: Need help with 68-72 stepside longbed fender with spare tire cut out
Have you considered just taking a non-cutout fender and adding the smaller LWB cup? Since the factory rolled the flange over and welded in a formed cup it would be easy enough.
If it helps here are part numbers I compiled. stepside fenders 67 left wo/spare 3882659 left 115" w/spare ??? left 127" & 133" w/spare ??? right 3881660 68-72 left w/marker wo/spare 3960559 right w/marker 3960560 left w/marker 115" w/spare 3960563 left w/marker 127" & 133" w/spare 3960565 boards 67-72 left 115" 3879177 right 115" 3879178 left 127" 3882559 right 127" 3882600 left 133" ??? can anyone confirm this as 3882601 right 133" 3882602
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-04-2016 at 04:50 PM. |
Tim, thanks for your idea. Lucky for me I found the correct fender in FL and have just had it blasted. I will be fitting it to the truck this weekend.
Sounds like a plan!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
From my clip art folder...
| Bookmarks |
| Tags |
| cutout, fender, spare tire, stepside |
