Closed Thread
Old 03-05-2016, 08:43 AM   #3326
tlman
Re: What did you do to your truck today? Chapter II
rad support on ,one fender for stability checked wiring location ,rad too big ,found one right size in storage trailer out back hoses from 85 fit perfect
cant wait for it to roar to life
tlman is offline
Old 03-05-2016, 10:01 PM   #3327
orangek5
orangek5's Avatar
Installed a new fuel pump and bed
Before:
During:
After:
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline
Old 03-07-2016, 05:55 PM   #3328
73737373
Got a couple things done.
73737373 is offline
Old 03-07-2016, 07:32 PM   #3329
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I just love the details. Did you just wash under the hood or respray it?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 03-07-2016, 08:07 PM   #3330
RodnRudy
RodnRudy's Avatar
Got the passenger side inner rocker fit up and welded in.
RodnRudy is offline
Old 03-08-2016, 12:04 PM   #3331
Mator
Mator's Avatar
Well it seems I caused myself more work. I went to move the truck the Sunday night and found the dash lights not working. I dug into it last night figuring it was just a ground. After checking all the grounds I also noticed no parking lights, running lights or break lights not working. It really surprised me because I have been driving it and didn't notice it. Come to find out when I installed my new door sill I screwed through the wire for the dome light and grounded it out and blew a fuse. Now I stripped a screw and have to find a new one at Fastenal. Two steps forward one back.
Mator is offline
Old 03-08-2016, 10:44 PM   #3332
tlman
installed modified brake booster from a 1980 1500 ,where most of my drive line conversion and parts came from, fabbed new linkage and installed master cylinder ,now the fun of plumbing all the lines
overhauled alternator and cleaned it in blaster
made all new battery cables and installed and began connecting harness
tlman is offline
Old 03-08-2016, 10:54 PM   #3333
Andy4639
Old member
Andy4639's Avatar
Question Re: What did you do to your truck today? Chapter II
Do you know if a stock master cylinder will bolt up to the newer vacuum booster?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 03-08-2016, 11:00 PM   #3334
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
I took the old cut off on the negative side of the battery off and put a regular mount back on it. The local car audio guy said it was what was making my lights go deem at night. I also polished up the new inserts I bought last week.
Oh I fixed the power steering leak also.
Andy4639 is offline
Old 03-08-2016, 11:02 PM   #3335
tlman
it takes a lot of research to build one of these ,my second in 30 years ,a lot more options in parts you just have ti take time and match up parts ,there are too many variables to answer that
tlman is offline
Old 03-09-2016, 09:46 PM   #3336
firedemon
seat and steering wheel today
firedemon is offline
Old 03-10-2016, 04:51 AM   #3337
Ringo934
Ringo934's Avatar
Today I blacked out the custom grille to better hide Ole Blu's missing tooth as you can see in the before picture. Also I removed the bug screen the previous owner had on there and installed the hood emblems. At first I had just removed the billet grille, but I didn't like the emptiness. So I sandblasted the chrome off and painted it black. There was too much chrome anyway, and I was never really happy with the way it looked. I'm happy with the way it looks now. Still working on the bed. I'm finally done sanding now. I just need the rain to stop so I can stain and seal it.
1969 GMC C/1500 LWB Wideside
355 SBC/TH400/3.73 posi-traction
Daily Driver.
Carburetors, because I don't care to consort with that of the robot race.
Ringo934 is offline
Old 03-10-2016, 07:29 AM   #3338
Econman
Econman's Avatar
Looks much better IMO. Nice!
Econman is offline
Old 03-10-2016, 08:17 AM   #3339
chevy2tom
chevy2tom's Avatar
Much better, looks good
chevy2tom is offline
Old 03-10-2016, 09:14 AM   #3340
snipescastle2
snipescastle2's Avatar
Talking Re: What did you do to your truck today? Chapter II
received my exhaust tips yesterday, not to get the brakes bled, the E brake cables strung and Fire the beast up!!! Then it's off for my exhaust, alignment and then my safety inspection and finally, plates!!! here's a few shots of my exhaust tips and mufflers...
Yeah!!!
Ben
snipescastle2 is offline
Old 03-10-2016, 12:12 PM   #3341
70STOVEBOLT
70STOVEBOLT's Avatar
Made a bracket to hold my fuel pressure regulator in place. Gotta remove for paint and it will be done.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 03-10-2016, 10:12 PM   #3342
midniteblues
midniteblues's Avatar
Scrounged these things from the jy for the k20 not bad for A Couple of dollars.
of course a lil' clean up is necessary.
Still need 2 frame brackets that won't be easy to get off.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 03-11-2016, 08:27 AM   #3343
tlman
got a sweet set of wheels and tires on a barn find
tlman is offline
Old 03-11-2016, 04:23 PM   #3344
Possmguts
Possmguts's Avatar
Stuck these stainless steel headers on because its the only new part that was waiting on me when I got home this week... meanwhile I'm still working on that hood....
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 03-11-2016, 09:20 PM   #3345
VWNate1
VWNate1's Avatar
THANK YOU ALL for the wonderful pictures ! .
They keep me motivated even though my truck is just sitting in my driveway inoperable and I have the bed full of parts as it's blocking one of my daily work spaces....
I walk past it multiple times a day and curse the body shop but I do have a plan , a long and slow one but I want to drive it again so badly.....
I look at everyones hard works and dream of clattering and wheezing down the road again with a load on and my elbow out the driver's side window .
I see one removed the stepside bed and installed a fleetside ~ I cannot imagine this but I'm a Farm Boy who loves and needs those steps for work / loading =8-) .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 03-11-2016, 09:38 PM   #3346
70STOVEBOLT
Today I put the new fuel line from the pump to the carb on and when I was tightening the line at the pump, I apparently over tightened it and the pump started leaking. So I also installed a new fuel pump. I guess I don't know my own strength. Hey Rocky, watch me pull a rabbit out of my hat!...
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-11-2016, 10:04 PM   #3347
PIG-TECH
PIG-TECH's Avatar
Got it running today. had some electrical issues, thanks to the replies and older post with wiring diagrams, Awesome Chevy & GMC site
PIG-TECH is offline
Old 03-11-2016, 11:30 PM   #3348
MikeB69C10
MikeB69C10's Avatar
I got rid of this...
MikeB69C10 is offline
Old 03-12-2016, 07:31 PM   #3349
firedemon
picked up one of these today now to find someone to go through it
Old 03-13-2016, 02:43 PM   #3350
Possmguts
Possmguts's Avatar
Got this a few steps closer to being done...
Closed Thread
