Old 03-05-2016, 06:54 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc brake drop spindles and stock height spindles
Originally Posted by SoCoC10 View Post
The 3" drop spindles will require you change your lower ball joint to a 69-70 ball joint. The stock height spindles will bolt right up.
To install a 63-70 spindle on a 71-72 truck,... you need to change the upper and lower balljoints and the outer tie rod ends.
Everyone needs to research what they are buying and selling, so there is no hard feelings.
Keith
Convert to disc brakes.
lolife99 is offline
