Old 03-04-2016, 10:24 PM   #1
Sim6
Sim6's Avatar
OG gauges with 90ohm sender
Found this while cruzin the web. Have any of you done this on a s10 or other?
Jeff
http://www.oldengine.org/unfaq/oddbits.htm
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 03-05-2016, 08:57 AM   #2
1project2many
Re: OG gauges with 90ohm sender
This will work. The gauge will be slightly off at middle ranges but you probably won't even notice it. You don't have to solder the resistor at the sender. You can attach it at the instrument cluster or as part of the harness. That way if you need a replacement sender you can use a stock one without modifications.
1project2many is offline   Reply With Quote
Old 03-05-2016, 09:20 AM   #3
Sim6
Sim6's Avatar
Do you replace the wire with the resistor just splicing it in anywhere?
Old 03-05-2016, 09:25 AM   #4
joedoh
joedoh's Avatar
no, that would be putting the resistor in series, and would not work.
Old 03-05-2016, 08:20 PM   #5
1project2many
The resistor must "Tee" off the sender wire and connect to ground. When done correctly there will be two connections t make:
---------------/\/\/\/\----GND
|__________Sender________GND
