stock steering wheel position (measurement)
Re: stock steering wheel position (measurement)
Only help I an offer is that the distance between the front glass and the steering wheel would be a 6 1/8", that could set your column position.
No glass in the truck at the moment, thanks anyway
Posted via Mobile Device |
Put a straight edge horizontally across the opening, should get you close.
I'll give it ago later thanks
12 inches to the top side of the rim from the factory AD column mount. Fit to match the wheel you are running so the wheel won't be in the wrong spot like the late model wheel is on my 48.
This is in my 51 1-1/2 ton. ![]()
thats great mr48chev, just what i needed to know
thanks ian |
Just for added measure.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
