Old 03-07-2016, 08:06 AM   #1
PDXGraham
Fuel tanks and EFI
I wanna run aftermarket EFI on my 68 CST and was wondering what you guys out there for for EFI compatible Fuel tanks, I really don't wanna spend $600+ on a fancy aluminum tank. Anyone use a later blazer tank?
PDXGraham is offline   Reply With Quote
Old 03-07-2016, 02:29 PM   #2
MARKDTN
Re: Fuel tanks and EFI
I used a '85ish (TBI) S10 Blazer tank on a '72 SWB I did for a guy. Just swapped to a TPI pump and it worked great. I used lines and all. Did have to do some frame notching to fit it in, but nothing huge.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-07-2016, 03:02 PM   #3
67 chevelle
67 chevelle's Avatar
many use a jeep grand Cherokee tank for e f i
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-07-2016, 04:04 PM   #4
72MARIO
72MARIO's Avatar
Any pitcires of that grand cherokee gas tank installed ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-07-2016, 04:06 PM   #5
lutronjim
Tank I used under my 70 C10.
http://www.tanksinc.com/index.cfm/pa...rod/prd378.htm
$225
lutronjim is offline   Reply With Quote
Old 03-07-2016, 05:07 PM   #6
Matt Cramer
I dropped a high pressure pump into the stock fuel tank to see if it could be done. It worked. If I were to do things over again, however, I'd have gone with a tank under the bed as the cab still sometimes smells like gas fumes. Or at least used an external pump as it's a bit loud to have the fuel pump just a foot behind me.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 03-07-2016, 05:18 PM   #7
PDXGraham
Which grand Cherokee? A ZJ?
Old 03-07-2016, 05:40 PM   #8
Z10
Z10's Avatar
Why not use your existing tank and add a surge/sump tank. We built one to use on a TPI system for my truck (see build thread below) and I'm using the FiTech system and there sump tank on my 69 Camaro.
http://fitechefi.com/default.asp.pg-...lCommandCenter
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-07-2016, 05:41 PM   #9
PDXGraham
I wanna move to rear tank and clean up the look of the cab/fumes
Old 03-07-2016, 06:27 PM   #10
67 chevelle
I think its a 86 or 96 grand cherokee , and I used a 01 silverado in tank fuel pump , ill check on tank tomorrow and let you know , the hole where the pump goes in had to be enlarged slightly
Old 03-07-2016, 07:57 PM   #11
Tkmadone
I used a 30 gallon tank from a '88 Suburban. Had all the efi stuff and fits perfectly between the frame rails.
Tkmadone is offline   Reply With Quote
Old 03-07-2016, 08:10 PM   #12
72MARIO
72MARIO's Avatar
I have a 1996 grand cherokee here that use to be our daily driver. If that fuel tank will fit in our 1968 suburban that would be awesome !
2005 TAHOE DD
Old 03-07-2016, 09:35 PM   #13
67 chevelle
90 jeep wrangler with 03 silverado pump , some fab required , sorry about the gran cherokee , but they may be the same not sure, the "lips" on the sides of the jeep tank line up with our frame rails , overlap so the it can be bolted to the frame behind the differential , one small crossmember has to be removed , I reinstalled in to add additional support to the tank , check the ls thread on this board , and ls1 tech.com , conversions and hybrids
