Old 03-06-2016, 11:52 PM   #376
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Nice work... she's really coming along!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 03-07-2016, 03:07 AM   #377
62stepside longbox
62stepside longbox's Avatar
Thanks Johnny
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-07-2016, 10:43 PM   #378
62stepside longbox
Did some work on my sending unit today. The sending unit for my underbed tank was a 90 ohms while the factory tank and gauge are 30 ohms and since I wanted to keep the original gauge I robbed the transmitter part of the 30 ohm sending unit and tacked it on to the sending unit for the new tank. Then I soldered the connection and bent and cut the float arm so that it matched the 90 ohm one and stuck the float from the 90 ohm onto the 30 ohm. Tested it with the multimeter and it works great
The 30 ohm transmitter bent and cut and the new float on to the same dimensions as the 90ohm transmitter
Old 03-07-2016, 10:46 PM   #379
62stepside longbox
And here it is tacked in place and connections soldered
Old 03-07-2016, 10:48 PM   #380
Classic v6 GMC's
Classic v6 GMC's's Avatar
Nice work!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-07-2016, 10:55 PM   #381
62stepside longbox
Originally Posted by Classic v6 GMC's View Post
Nice work!!
Old 03-08-2016, 11:34 AM   #382
65sub
65sub's Avatar
Great work Nik. I admire your "work with what you have" attitude. You don't just order parts from a catalog.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-08-2016, 11:50 AM   #383
62stepside longbox
Thanks Dale, it just kinda clicked in my head that even if all these aftermarket parts weren't available It wouldn't really make a difference as I have bought next to nothing new for it, well that and I'm cheap
Old 03-08-2016, 06:52 PM   #384
Originally Posted by 62stepside longbox View Post
............... and I'm cheap
I think that is pretty applicable to most of us!
Old 03-08-2016, 09:59 PM   #385
62stepside longbox
Ha ha yeah your right about that
Old 03-09-2016, 03:29 AM   #386
Grizz1963
Grizz1963's Avatar
Clever guy.
I love the way you just figure stuff out and get on with it.
What does your family think of all the work you are doing?
And as far as being cheap......... I LOVE THE SOUND OF CASH JANGLING IN MY POCKET !!!
It certainly beats the sound of it landing on somebody's counter top....... Also means you can use it another day for something more important.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 03-09-2016, 12:05 PM   #387
62stepside longbox
Originally Posted by Grizz1963 View Post
Clever guy.
Thanks rian, its support from people like you that help me get motivated. my family thinks what I'm doing is great especially my dad since I'm digging way deeper than he did with any of his cars. And you know there ain't nothing better than the sound of change jangling, I'm saving it for a rainy day.
Old 03-09-2016, 11:04 PM   #388
62stepside longbox
I have to say I really like the looks of the 60-66 body style, not much I would change but the one thing that bothered me was how big the gap between the top of the wheel and the fender lip. I got the idea from vin63's build. So today after school I got busy and started cuting. I added 2 1/2''. Worked through the rain but still made progress. Welded about half of it up. Here is the 2.5'' panel welded in and the lip mocked up
Old 03-09-2016, 11:07 PM   #389
62stepside longbox
Then I cut the lip section in half and moved them apart by an inch so the lips line up and welded in. Only finished one of the two peices of the lip. I should have it done tomorrow
Old 03-09-2016, 11:08 PM   #390
62stepside longbox
500th post! And this is the picture from vin63's thread where I got the idea
Old 03-10-2016, 03:12 AM   #391
Grizz1963
Grizz1963's Avatar
....... And THAT my friends...........
Is Hot Rodding.
Old 03-10-2016, 05:39 PM   #392
62stepside longbox
Is Hot Rodding.
Thanks rian. Your right, even though I won't be going anywhere fast it'll still be a cool hotrod.
Old 03-10-2016, 10:07 PM   #393
62stepside longbox
Did some more work on the fender sectioning. Cut and tacked in the rear portion. Now I just need to weld in the centre section.
Old 03-10-2016, 10:09 PM   #394
62stepside longbox
I also started on shortening the driveshaft. I grinded the weld down on the camaro yoke till I could see a little crack then I tapped it with a hammer and it came right off, then I cleaned off the rest of the welds. Now I just need to measure and most importantly cut it square and carefully weld the camaro yoke to the original driveshaft
Old 03-10-2016, 10:41 PM   #395
TJ's Chevy
TJ's Chevy's Avatar
Looks good buddy! Be Super careful on getting that yoke on there. Ya don't want it to be off because vibrations can cause severe problems.
Old 03-10-2016, 10:48 PM   #396
65sub
65sub's Avatar
Nice job on the fender Nik. I'm interested in seeing it finished
Dale
Old 03-10-2016, 11:05 PM   #397
60chevyjim
60chevyjim's Avatar
great job on your fender !!
I have been thinking about doing the same thing for a while now
I need the front fenders to hide the tire without doing air ride .
good to see your doing the driveshaft too.
make shore both u joints are lined up the same.
I would take the yoke off so you can use the square to check it to make shore you have it straight both ways
before you do any welding .
60chevyjim is offline   Reply With Quote
Old 03-11-2016, 02:57 AM   #398
62stepside longbox
Thanks tj. Don't worry I'm going to check that it's square a thousand times before I do any welding.
Thanks Dale, I'm leaving on a trip to Maui tomorrow for a week but I'll get right back on it when I return and I'll be sure to share pics.
Thanks Jim, yes I was planning on taking the yoke off. I found a great way to cut the driveshaft straight, I got a piece of tubing with a flat end that just barely slides over the driveshaft so I can mark and cut up against the tubing. Could you send a pic showing how you square up the yoke? Thanks for all the help.
Old 03-11-2016, 10:55 AM   #399
AJCK87
Like the work! Making good progress
AJCK87 is offline   Reply With Quote
Old 03-11-2016, 11:52 AM   #400
62stepside longbox
Thanks, your making good progress on your panel truck as well.
