got in wreck cause steering colum came apart
Well guys coming home from work yesterday on 175 atlanta traffic going 60mph the lower steering bearing came apart resulting in steering arm coming off. I went across 3 lanes of traffic and hit a bmw and hit the concrete wall. Spent the night in hospital. I need a front drivers fender a grill a bumper and steering columm. I found a local steering column out of a 85 c10 will. That work in my 69?
![]() Join Date: Jan 2010
Re: got in wreck cause steering colum came apart
Glad you are ok. That does not sound like a good situation. just curious was this a stock column or aftermarket tilt?
The 85 column is not a direct bolt in. Could probably work wit some fabricating.
Take it easy and get well soon. I have never heard of a stock column doing that. I know some aftermarket tilt columns are poorly made that's why I asked.
![]() Join Date: Mar 2003
I would really like to see what came apart. Sounds like some sort of major failure to completely loose control. Steering column is designed to still have sort of control in the event of failure. You can loose the lower bearing and the rag joint at the box and still retain some sort of control for a while.
#8 | |
Glad your ok, and the others I assume. From the sounds of it, it's hard to imagine that's all you need for parts.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Im amazed thats all i need too, tough truck is all i got to say bout that.. i got out expecting the worst but was suprized at the little damage to truck. And thanks for your concern. Im ok just in pain trucks in better shape than me haha
Old member
First glad your ok. That is the main thing. The truck as you know can, will be rebuilt better than before.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Losing steering has got to be the worst system of all to have go out on you.. I'd rather have the brakes go because at least there would be hope for a choice of what to steer toward and hit to stop.. in other words between that oncoming truck head on - or that chicken coop in somebody's yard; aim for the coop!
Three lanes of traffic - I hope you mean they were all going in the same direction as you and not head on - There is a two lane road near my home with a long flat straightaway where people routinely seem to just want to naturally drive at 85.. so as you motor down that road the high speed oncoming traffic is just three feet away from your left shoulder and even doing 65 mph (no doubt with five cars buzzing angrily on your bumper) every time you feel that whoosh of the oncoming car going by it is a reminder that your closing speed is probably 150 mph... (and we've seen the NHTSA videos for 100+ mph crashes ...gulp). NASA would have a checklist for a system as risky as this.. maybe to preserve board members we can come up with a steering system checklist and prevent this from happening to anyone else.. Glad you wrote to tell the forum and glad you are okay to tell the tale. As far as your question - I have been tempted by those IdidIt columns - because the NOS and limited repop GM steering column parts seem to be really expensive for what you get and relatively hard to source - also the sloppy shifter syndrome seems all too common and hard to fix - so if it were me I would take the opportunity to try the IdidIt product. |
Man I hate seeing posts like this. Its great that you're ok though cause these trucks can always be fixed but us not so much. Hopefully your truck gets back on the road soon!
#15 |
glad you are ok, weird that your steering failed like that
#16 |
I'm also glad to hear you weren't hurt worse or dead! Suddenly having excessive play at hiway speed is a thing few have experienced. Many know what getting in a truck and driving with sloppy steering is like and/or a truck that pulls in one direction or the other. You figure how to compensate and get on down the road. The darts are consistent and within a tolerable range (just from slightest wear movement). In this case, the compensation didn't do what was expected any better than going straight was working with the dart extreme. I imagine the bearing balls came out of the races after a long period of being dry?
I had a steering box coming loose with a cracked frame that sent me over into the car next to me on a multi-lane road on a Blazer I had. I was on my way home from 4 wheelin' which was when frame cracked and box started working loose. Off road in 4wd I couldn't tell. It felt funny once on the road and I stopped and checked it out best I could, being alone. I was aware of the sloppy steering and I was doing ok, but still had a problem. It went from perfectly normal to WTF? and back randomly. Both vehicles "buffed out".. I should have parked it and had it towed
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-09-2016 at 10:23 AM. |
#17 |
![]() Join Date: May 2014
Wow, that really sucks. Had to be a scary few seconds. Glad you and everyone involved is okay. Hopefully you're able to get your truck back on the road
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
#18 |
Still Learning
Glad you're okay! Sounds scary! Did you get any pictures of where the failure happened? If nothing else, you can warn others of potential problem in the future.
#19 | |
#20 | |
![]() ![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#21 |
Good to hear you're ok. I can't believe it wasn't worse, what a terrible feeling to loose steering. And the minimal damage to you're truck considering what happened, lucky guy. Hope you find everything you need
#22 |
That part you found on the road is from another vehicle, and probably not steering related. However, I see why your steering failed. Yes, the lower bearing in the steering column is gone, but that would not cause loss of control. The coupling at the end of the steering column came apart because the bolt that is being used to secure the lower shaft to the splined end of the steering column is too small in diameter to engage the "cut out" slot in the splined shaft. When the proper size bolt is used, there is practically no way for the coupling to come apart, even when the bolt is loose. You have to completely remove the bolt to separate the two sections. Your problem was the result of a sketchy fix on the coupler. Its a good thing nobody came after you with a lawsuit, because you would have been 100% liable.
#23 |
Thanx guys ill get it fixed, im a paint and bodyman in shop so just gotta find some parts
#24 | |
#25 |
Any shop like LMC, Brothers, etc. will carry the lower bearing. They will probably also carry the coupler/bolt kit. The bolt is actually a carriage bolt with a square shaft on one end that engages the coupler to keep the bolt from spinning while you tighten the nut on the other end. Everything should cost less than about $20.
