Closed Thread
Old 01-27-2016, 08:58 PM   #1
Tims71
Extra new parts
I have the following parts for sale that I am not going to use from my 71 build
CPP Trailing arm crossmember mount 175.00 New ( With hardware ) Sold
CPP C- Notches 70.00 ( with Hardware )
Pair new never ran Nascar truck arms from Richard Childress 150.00
Plus Shipping
Tims71 is offline
Old 01-31-2016, 12:19 PM   #2
Tims71
Re: Extra new parts
pics added
Tims71 is offline
Old 01-31-2016, 01:09 PM   #3
paul mora
Re: Extra new parts
If those are 2 inch blocks are they for sale
Pulatoy
paul mora is offline
Old 01-31-2016, 03:52 PM   #4
Tims71
Re: Extra new parts
Sorry the blocks are not for sale yet but may be soon
Tims71 is offline
Old 02-03-2016, 09:01 PM   #5
Tims71
Re: Extra new parts
Ttt
Tims71 is offline
Old 03-02-2016, 06:41 PM   #6
Tims71
Re: Extra new parts
The Crossmember is sold. The C Notches are the standard 1/4" steel plate not the 3/8" Sorry for the mistake. Will take 70.00 plus the shipping cost for the notches. Trailing arms are still available
Tims71 is offline
Old 03-02-2016, 07:34 PM   #7
Possmguts
Possmguts's Avatar
Re: Extra new parts
Nascar Truck arms you say? Got a better pic of them and do they need any mods to bolt up anywhere?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 03-02-2016, 08:03 PM   #8
Tims71
Re: Extra new parts
You need the bushings at the crossmember. There are shock mounts tacked in place. I do not believe any mods need to be done depending on what your build is going to be.
Tims71 is offline
Old 03-02-2016, 09:00 PM   #9
Possmguts
Possmguts's Avatar
Re: Extra new parts
Are those bushings not the same as the factory ones? I just put new urethane ones on along with with everywhere else... Its a full frame off deal. But I did a static 5" drop.
What do you mean by "tacked" in place? I have a shock relocation kit installed with the shocks mounted behind the rear end out board of the frame.
From what I can see in the pic, they look pretty much like the factory ones except there is no seam down the center.... is that right?
Old 03-02-2016, 09:09 PM   #10
Tims71
Re: Extra new parts
There is a seam but they are reinforced a lot more than stock. As for the bushings if you want to use the ones you have you can have an insert turned at a machine shop which is what I did on the las one we did and it worked great. The shock mounts are just tack welded for mock up and are easily removed
Tims71 is offline
Old 03-02-2016, 09:57 PM   #11
Possmguts
Possmguts's Avatar
Re: Extra new parts
I think if you still have them this weekend I may take them... Ill get back at you. My rear suspension is finished, but Im always willing to upgrade even more at the right price.
Old 03-10-2016, 01:27 AM   #12
crakarjax
crakarjax's Avatar
Re: Extra new parts
ttt
1968 LWB C20 / AC / Wood Bed
crakarjax is offline
Old 03-10-2016, 09:35 AM   #13
fredm98
Active Member
Re: Extra new parts
I'll take the Cpp notches.
fredm98 is offline
Closed Thread
