Old 05-18-2014, 12:15 AM   #1
bab59
Cpp C -Notch 60-62? #6372cnk HELP
Looking to buy a C notch kit. Cpp has a part number "#6372CNK 1963-72, kit". The question I have is why only 63-72? Why would this notch not work on a 1960-1961-1962?
I have a 1961 C10 I am looking to notch.
Would it work on my application?
bab59 is offline   Reply With Quote
Old 05-18-2014, 12:56 AM   #2
losthope
losthope's Avatar
Re: Cpp C -Notch 60-62? #6372cnk HELP
different frames , 63-72 had ladder bar frame and 60-62 has x-frame...ive only had 63-66 trucks so I cant tell you for sure why, but I assume the frame curvature on the 62 and under is different above the axle area where the notch would need to be installed...
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 05-18-2014, 01:11 AM   #3
losthope
losthope's Avatar
heres a 60-62 x-frame , if you notice its pretty straight on the side rails of frame looks to be close to the same width all the way back to the rear frame :
http://i311.photobucket.com/albums/k...a/IMG_8214.jpg
http://img16.imageshack.us/img16/1973/060qvx.jpg
and here is a 63-72 frame you can see they are totally different and that the ladder bar frame curves/tapers back in towards the rear so the rear frame width is smaller dimension width then the middle of frame and the c-notchs are made with this taper in them:
http://i1178.photobucket.com/albums/...23Nov11001.jpg
And that there is the reason the 63-72 notch will not work on your frame
heres a simple pipe notch in a x-frame
http://67-72chevytrucks.com/gallery/...425x425Q85.jpg
Timmy D.
Old 05-18-2014, 08:03 PM   #4
LVPhotos
LVPhotos's Avatar
If a little notch is needed use 5" pipe to get where you want. Or PorterBuilt has big ones. I did 2"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-18-2014, 08:06 PM   #5
LVPhotos
LVPhotos's Avatar
Ride height. Stock torsion front for now. Have PorterBuilt front crossmember to be installed.
Old 05-19-2014, 11:39 AM   #6
bab59
That looks good. I have a 78 crossmember I am going to be swapping, and it has 2.5-3" Drop spindles. Did you box any of the rear frame in after the pipe?
What rearend are you using?
Old 05-19-2014, 06:52 PM   #7
LVPhotos
LVPhotos's Avatar
The 62 frame is boxed in that area from factory. Bottom pic shows inside frame.
Old 12-31-2014, 01:47 PM   #8
Boomscatty
Do you have any pictures of the inside of the frame after notch??
Boomscatty is offline   Reply With Quote
Old 12-31-2014, 01:50 PM   #9
LVPhotos
LVPhotos's Avatar
It's a pipe. Solid and frame is boxed there.
Old 12-31-2014, 05:31 PM   #10
LVPhotos
LVPhotos's Avatar
Zoomed in.
Old 12-31-2014, 07:02 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I would only go halfway thru the frame with the pipe notch and also boxing it. I thought of doing this, but I pull a trailer from time to time and worry about the strength after a mod like that.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-31-2014, 07:33 PM   #12
LVPhotos
LVPhotos's Avatar
The 60 to 62 frame is already boxed at that point. Used a 5 inch pipe and made 2.5" notch.
Old 12-31-2014, 08:31 PM   #13
Boomscatty
How thick of pipe did you use?
Old 12-31-2014, 08:39 PM   #14
amueller454
amueller454's Avatar
i did this mod as well using 5" i.d. pipe. It was schedule 40 so 1/4" wall. I think it should hold up just fine
1960 short bed fleetside factory 4x4
1960 panel 454 NV4500 Daily driver
1961 Short Bed BBW Fleetside 5.3 th400 swap in process
amueller454 is offline   Reply With Quote
Old 12-31-2014, 09:14 PM   #15
LVPhotos
LVPhotos's Avatar
3/16" I believe.
Old 03-08-2016, 02:30 AM   #16
ebaby35
Where are those trailing arms from? And bags?
ebaby35 is offline   Reply With Quote
Old 03-08-2016, 05:58 AM   #17
lolife99
67-72 parts collector,…
lolife99's Avatar
www.pbfab.com
Keith
Convert to disc brakes.
Old 03-08-2016, 04:16 PM   #18
ebaby35
Hey sorry looked on pb but can find were these for later year or specific
Old 03-08-2016, 04:36 PM   #19
lolife99
lolife99's Avatar
Contact Porterbuilt.
They make all their parts per your order.
They won't sell you parts without talking to you first.
Great product.
Even better customer service!
Keith
Old 03-08-2016, 07:37 PM   #20
bstash19
Great product.
Are you using their parts on your truck? How low are you?
bstash19 is offline   Reply With Quote
Old 03-08-2016, 08:09 PM   #21
lolife99
lolife99's Avatar
I don't own a 60-66 truck. But I have purchased many parts from www.pbfab.com for 67-72 and 73-87 trucks.
QUALITY PRODUCTS!
Keith
Old 03-08-2016, 09:07 PM   #22
LVPhotos
LVPhotos's Avatar
The standard Porterbuilt arms will work with the adjustable links. I opted for 1/2 longer. The bags are Firestone 2500 but 2600 that are on front might be a little softer. Nate and Dave are great with answers.
I went 1" drop built in, there is a 3" as well.
Old 03-08-2016, 09:34 PM   #23
bstash19
QUALITY PRODUCTS?
I've heard nothing but good things about them. I'll definitely give them a call when I'm at that point.
Old 03-10-2016, 02:00 PM   #24
ebaby35
are the trailing arms the same in both pics?
Old 03-10-2016, 04:16 PM   #25
LVPhotos
LVPhotos's Avatar
No. The lower one is stock arms ,boxed and powder coated black.
